changing the idle on 03 gsxr
Old Aug 18, 2006 | 11:03 AM
om295's Avatar
om295 is an unknown quantity at this point
can any one tell me can you add the twist screw set up on a gsxr set screw like you can the honda's so you can move the idle up[ and down easy and if so sort of give a run throgh on it .....help im new and dont know what to do lol...
Old Aug 18, 2006 | 01:16 PM
binder929rr's Avatar
back in the saddle again
Re: changing the idle on 03 gsxr
buy an idle adjuster from an older gixxer (2000-2001) and remove the idle set screw on the left side of the carbs and install the idle cable in there....done.
Old Aug 18, 2006 | 02:50 PM
KF_Chris's Avatar
KF_Chris is a decent person
the 01 750 had one, not all the old ones did.
Old Aug 18, 2006 | 02:56 PM
J-cheezy's Avatar
J-cheezy is a decent person
I got a cable from a 97 900rr that my friend had layin around it wouldnt fit the threads are different so I just welded it to the end of the stock idle screw and I havent had any pyoblems out of it
Old Aug 18, 2006 | 08:52 PM
i'm pretty sure 00-03 750's had them. mine is an 02 motor. i think they stopped putting them on the 600's in like 03. i know the 03 1000 doesn't have it either cause my friend dan's didn't have one.
Old Aug 19, 2006 | 03:04 PM
Danger_Dave's Avatar
brabuhburbuh
no, the 2000 model 750 is the only gixxer that has one. that is the one you need to order. some of the 600's have a choke on the handlebar, but thats it.
get the bracket with it too, that way it attaches to your fairing and doesnt flop around.
Old Aug 19, 2006 | 03:22 PM
celgsxr's Avatar
From: Motor City Freestyle in Detroit Michigan (0-o)
celgsxr has much to be proud ofcelgsxr has much to be proud ofcelgsxr has much to be proud ofcelgsxr has much to be proud ofcelgsxr has much to be proud ofcelgsxr has much to be proud ofcelgsxr has much to be proud ofcelgsxr has much to be proud of
o6 r6 is same thread to
Kerns BBO
Apr 29, 2013 12:34 PM
kntmare181
Feb 14, 2013 01:00 AM
xxSHANNONxx
Jan 22, 2013 10:57 PM
hondacrf150f1
Dec 3, 2012 10:04 AM
hondacrf150f1
Dec 1, 2012 11:34 AM
