seat stander help
Old Aug 10, 2006 | 01:48 AM
louisvillerider's Avatar
seat stander help
well i been doing SS's w/ out a hb... keeping them pretty slow for just throttle controll, but came back too far and scraped, and the bike tisted... ended up loosing it from 12... is there any way to get the bike off the bar w/out a HB from a SS?
Old Aug 10, 2006 | 02:01 AM
crtchrktrcr's Avatar
B.T.M.
Re: seat stander help
come in fast, high rpms.. engine brake it, pull in clutch, scrape.. let rpms drop, let out clutch...
Old Aug 10, 2006 | 09:54 AM
misunderstood me..... im talking about if i happen to loop out while on a SS to the bar.... not intentionally. so i just pull in the clutch, and let it back out for the EB to bring me off?
Old Aug 10, 2006 | 10:06 AM
rcklssr6's Avatar
rcklssr6 is an unknown quantity at this point
The higher your rpm's are at, the more engine breaking you will have. so if you think your comming back to far just let off the gas and if your at high rpm's the engine break should bring you back. If you want to scrape come in again at high rpm's bring it back slowly using the engine break, when your real close to scraping pull in the clutch let the bike scrape -rpm's will be dropping-then let out the clutch, the engine will catch and pull you back down. It also helps to lean foward and kind of bench press ther bike back down if you think your back too far. Good luck.
Old Aug 10, 2006 | 10:14 AM
cool.. i scraped it on accident, and lost it.. was wondering how to prevent loosing it again.. thanks
Old Aug 10, 2006 | 11:07 AM
If you're going slow, its not coming back from clutching. At that point you have to park it or let it fall.
If you have some speed, the moment you know its going to loop, pull in the clutch so you dont lose any speed. Even if the bar is still 8 inches off the ground, pull in the clutch and let it gorilla scrape.
Old Aug 10, 2006 | 01:01 PM
B.T.M.
if u hit the bar.. just pull in the clutch.. n hope it doesn't twist
Old Aug 10, 2006 | 02:00 PM
yeah i was going slow, not over clutching
thats what happened though, as soon as it hit it twisted, i grabbed the clutch, but did no good, so i let it go. i didnt fall, but it bent my FI cage, and bolt for motor mount
Old Aug 10, 2006 | 02:01 PM
B.T.M.
make sure to keep soft bolts in the cage.. u deff dont' want one to snap.. and that way, it bends, and then takes .35cents to replace
Old Aug 10, 2006 | 05:17 PM
thanks good looking out! it also bent the brace that goes back to the rear mount, so ill have to heat/bend that back too
Old Aug 10, 2006 | 09:40 PM
N*A*M's Avatar
N*A*M is an unknown quantity at this point
seat standers are great fun with no hb
but i have no bar so bailing one wouldn't be fun
thanks for the speed and clutching tips
MsTandemTryOut
Missouri
May 26, 2013 03:32 AM
ACTION
May 9, 2013 10:44 PM
Kerns BBO
Apr 29, 2013 12:34 PM
zeus_r6
Dec 9, 2012 09:46 AM
Zero Descendo
Stunting Help and Advice
14
Nov 15, 2002 09:20 AM
