02 gsxr600 lil problem
i just gat the bike its my 1st bike and i think i locked it with the key i turned the key left were it said lock and it would not turn on again wtf did i do? the fuses are good and the battery works
did i lock it how do i unlock it?
Re: 02 gsxr600 lil problem
if you turn it just a little past lock it says "park" or something, if you put it to that one the tail light stays on and it will drain your battery, its easy to confuse em to cause there really close, ive done it before, hope this helps
dont really know if this helps man, but on mine 600 K1 push down and to left to lock the steering. Push down and right and the steering is off. Push down and fully over to the right and its vaarooom time
PS the Haynes manual is invaluable when you own any bike even for seasoned mechanics (i guess)
i cant turn it on "p" i can only turn it ones to left and one time to right
1st theres "P' then lokc and then on and off thats it i checked the battery it work fine
it just has to be the battery how do i push start it ? have someone push it while i have the bike in 1st gear and hold the cluch in the let it go? will it jump?
what you do is run with the bike.. i say use 2nd gear, cuz 1st gear has too much compression and will lock the tire.. get runnin quick, and then jump on the bike, and pop the clutch give it some gas(make sure the key is on) and i don't think it'll jump man, do you know how to work a throttle n clutch?
Originally Posted by john3/1
dino did you turn your kill switch on its the red button on the right switch it down just to check.
thanks
sarkev
Stunting Help and Advice
Sep 4, 2014 06:49 PM
mackwilson21
Nov 28, 2012 05:42 PM
