Merk step's help
Old Jun 12, 2006 | 07:00 PM
-Ludo's Avatar
Yes guys, it really is me
-Ludo is a decent person
Talking Merk step's help
Ok, my idle is around 3000, now when i get it on the bar and start to run with it, i cant get it off the bar if i pull the bar brake to much it stalls out and drops down, if i let of the brake a bit it wont lift of the bar.
How do you lot keep it on bp when running with it???
Also, when doin merk steps from stand still, do you still use the bar brake or just clutch till it comes back to bp then back on the brake???
I'm trying jumpin to spreader first, is it best trying jumpin to seat stander first???
Thanks for your help and sorry for so many questions
Old Jun 12, 2006 | 07:09 PM
NINER's Avatar
Retired
Re: Merk step's help
Turn your idle down to 1,000. That is why it won't come up off the bar. Jump to sser first before jump to speader. It will help you from stalling and busting your *****. It isn't a hand brake trick. Push forward.
Old Jun 12, 2006 | 07:33 PM
-Ludo's Avatar
so idle really low and no brake??? ok, i'll give it ago. thanks for the help
Old Jun 12, 2006 | 07:52 PM
T-Dubby's Avatar
Brap
I would just clutch let the idle catch jump off and feather the hb and squeeze little more to make it start going down and jump on. I couldnt do it the other way without hb
Old Jun 12, 2006 | 08:06 PM
its harder with the handbrake than with low idle
Old Jun 14, 2006 | 08:33 AM
Insane J's Avatar
Uhm I do em, and I do em with High Idle, and just use the brake... simple...
The handbrake that is, but I just never let the bar hit the ground... I just still do a idle wheelie, but only then I'm running after it... So cause it's just a normal wheelie, I can brake as hard as I want, or give it more gas if i want to...
Simple, just don't do the merk steps scraping.... Just do em wheelie :YEAH The way they should go...
zeus_r6
Aug 23, 2014 04:11 PM
MsTandemTryOut
Missouri
May 26, 2013 03:32 AM
blarson27
Jan 13, 2013 07:33 PM
shugga
Nov 23, 2002 11:14 AM
