keep the gas?
Old Apr 21, 2006 | 12:47 PM
FallenWYN's Avatar
FallenWYN is an unknown quantity at this point
keep the gas?
Sorry for my lousy English. I just take my z1000 to wheelie and now there is a question, initially should I keep the gas and control the rear brake only? General speaking I loosen the throttle every time when it gets too high(actually it's not that high, maybe 45 degree or so) because of scare. I am afraid that brake controlling can not prevent loop if I keep the gas. stock everything.
Old Apr 21, 2006 | 12:55 PM
Wheeliest's Avatar
Scrapes Elbow
Re: keep the gas?
when i was learning brake control i'd keep constant pressure on the rear brake and use throttle to control height. if u keep pressure on the brake its almost impossible to go back words/loop
Old Apr 21, 2006 | 03:33 PM
Jaket's Avatar
Jaket is an unknown quantity at this point
Re: keep the gas?
If you use throttle and full power to bring it up, the brake is not enough. but if you cluth it up then it's ok to keep the throttle solid. well most of the time...
cott03_f4i
Aug 24, 2018 08:28 AM
exclusivelibray
Dec 16, 2016 09:59 PM
Duke_Montes
Aug 15, 2015 03:01 AM
Bjaroch
Jul 22, 2015 10:53 PM
Hoss
Jul 7, 2015 11:07 PM
