Low speed oscilation.
Old Mar 19, 2006 | 11:07 PM
Kolat's Avatar
Kolat is an unknown quantity at this point
Tonight I went out with the goal of hitting the 12 bar, dropped the tire pressure WAAY the **** down (mabey too much) and then was clutch them up at about 3mph. 954 with stock gearing. Bike would come up nicely but when I would try and ease it past the balance point once I got off the throttle the rear tire would start to oscilate side to side bigtime. I was sitting down, tried sitting up by the tank or on the back of the seat and it did'nt change. Any thoughts on what's causing this?
T
Old Mar 20, 2006 | 08:57 AM
verticaljay's Avatar
dedrater
verticaljay is a decent person
Re: Low speed oscilation.
The choppier you are with the throttle will cause the side to side wobble.
Old Mar 20, 2006 | 09:34 AM
EXMrider05's Avatar
EXMrider05 is an unknown quantity at this point
your bead is not slippin is it....
Old Mar 20, 2006 | 09:49 AM
NINER's Avatar
Retired
Low tire pressure can cause wobbles. Put more air in and see if that fixes it.
Old Mar 20, 2006 | 10:22 AM
Wheeliest's Avatar
Scrapes Elbow
practice idle before u plant that bar...
Old Mar 20, 2006 | 10:31 AM
f4stunna's Avatar
f4stunna is a decent person
if your trying to hit it for the first time do it stand up staggared.... slow sit downs tend to me more wobbly becuase you cant use as much body english to keep it straight.......
and dont try to force it onto the bar, you want to be riding along and pull in the clutch to set it down, then hit the break and clutch out to get off
Old Mar 20, 2006 | 11:22 AM
f4istunna's Avatar
f4istunna is an unknown quantity at this point
ya try staggered like f4stunna said easier to control and to bail if needed. lot of ppl swear by sitdowns for learning but it was way easier for me to learn staggered then it was all down hill from there. +1 on smooth throttle cant chop it on slow wheelies that will cause lots of wobble
Old Mar 20, 2006 | 11:31 AM
KF_Chris's Avatar
KF_Chris is a decent person
sitdowns are a beast....I'm glad I'm decent at them now after months of working on them.
Old Mar 20, 2006 | 05:55 PM
N/A's Avatar
N/A
The one thing I learned about sitdowns is if you can really learn your bike and pop the bike straight up to BP. I find that if you pull a sit down up and try to get to BP rather than snapping it up and catching it on the brake, you have to use a lot of body english to stabilize the bike up to BP. Personally, I like to just snap it to BP, then I kind of stick my knees rather than grip the tank b/c I use my legs to stabilize the bike.
Don't get down dude, it takes a while to get sitdowns... I still don't have them yet, they are a pain but once you get them you can do a lot from sitdowns.
Old Mar 20, 2006 | 10:33 PM
Danger_Dave's Avatar
brabuhburbuh
+1 on the body english
i started learning standing up staggered, but i wish i learned sitdowns first.
the transition of learning one thing before the other took alot longer than i think it wouldve if it was the other way around
Old Mar 20, 2006 | 11:08 PM
kj's Avatar
kj
same here... slow sitdowns for me are a b*tch right now.
aarona64
Nov 3, 2014 04:13 AM
DriftyStuff
Oct 4, 2014 10:59 PM
nver enf
Apr 11, 2014 09:44 AM
RL3000
Feb 21, 2014 04:47 PM
Ls1Mx5
Feb 6, 2014 10:44 AM
