using bark busters
Old Mar 1, 2006 | 11:01 PM
crazytexan's Avatar
crazytexan is an unknown quantity at this point
using bark busters
I am just wondering why everyone doesnt use bark buster like on dirtbike if you run the mx bar setup. save alot of levers. if you dont know what they are here they are....http://www.barkbusters.net/images/Prod_b14_large.jpg . how come yall dont use them?
Old Mar 1, 2006 | 11:24 PM
eazenutz33's Avatar
Re: using bark busters
never even thought of it I guess..........the name pulls us away as we don't see alot of tree action on purpose....might save some levers though, I'm sure all the DB bar haters would call it gay though....lol
Old Mar 2, 2006 | 11:52 AM
gsxtc's Avatar
gsxtc is an unknown quantity at this point
that is a good freakin idea!!
Old Mar 2, 2006 | 12:54 PM
hyperryder's Avatar
hyperryder is an unknown quantity at this point
i used them at one point they just get in the way to much
Old Mar 2, 2006 | 12:57 PM
hndarida4life's Avatar
hndarida4life is an unknown quantity at this point
i got them on my dirtbike now since everytime i lay it down the clutch breaks and i cant ride
Old Mar 2, 2006 | 01:21 PM
Angrish's Avatar
Angrish is an unknown quantity at this point
how did you mount them?
Old Mar 2, 2006 | 01:59 PM
DSOG Thomas's Avatar
***** gay.........if you guys would just cut like 2 inches off your levers before you ride then you wouldnt break em
Old Mar 2, 2006 | 02:16 PM
Lb3's Avatar
Lb3
areed. but clutch levers and perches are still a problem no matter how short you cut em if you have a hb unless you use aftermarket clipons. Best solution I have found is aftemarket (longer) clipons, leaving the clutch perch and mastercylinders a little loose and running short levers. works well.
Old Mar 2, 2006 | 03:35 PM
hyperryder's Avatar
same way as in the pic but to be honist stay away from them. the best thing to do is like every one else said cut 2 inches off but what i do is cut i tiny groov in my levers so when it dose hit hard enough it brakes off were i cut the groov and i can keep riding
Old Mar 2, 2006 | 03:42 PM
DBOUNCE1's Avatar
Damn that's a good call Ima do both of those tonight
Old Mar 2, 2006 | 03:44 PM
3824's Avatar
short levers
Old Mar 2, 2006 | 04:21 PM
tim 67's Avatar
tim 67 is an unknown quantity at this point
have you guys seen those levers that have a spring in them so they can bend back towards the inside of the bike, like towards the guage cluster, those are pimp but there pricy im surprised i dont see more people runnin them tho
Old Mar 2, 2006 | 07:18 PM
eazenutz33's Avatar
ASV levers, and yes they are pimp......but pricey, I got one on mine and its nice, already dropped it once and it slides right out of the way without any trouble.
My brake lever is already cut down to keep em from breaking, so good call there!!!!
Old Mar 3, 2006 | 07:44 AM
keep your perches loose and you wont have a problem i drop my bike every day and they dont break(then i got hand guards)it made it alot easer asv levers are too expensive and tey do break after awhile but they do.
markkellyjr
Feb 5, 2011 07:56 PM
projekt_eden
Dec 29, 2009 08:14 PM
ExtremeAcres
For Sale & Wanted
Jun 29, 2009 10:39 AM
skillz954
Feb 15, 2007 11:03 AM
