Frame Repairing
Old Feb 27, 2006 | 09:09 AM
KF_Chris's Avatar
KF_Chris is a decent person
Frame Repairing
We gotta fix the frame on the f4easy. Deal is that the mounts on the front, where the front upper part of the cage bolts to, both are bent in to the motor. Shawn's got most of the work done for pulling the motor out, and I'm gonna help him finish it off. From my experience, we're gonna heat the parts of the frame up a lot, and use a hyd. ram to spread the frame out to where the bent parts are straight again, using a 2X4 to spread the pressure of the ram. This should work, and shouldn't damage the frame in anyway. Sound about right?
Old Feb 27, 2006 | 09:24 AM
JohnnyP's Avatar
JohnnyP is a decent person
Re: Frame Repairing
Depends if the aluminum is stretched in anyway you'll never get it back to where it was.....If its a little bend you'll be able to get it close enough.
Old Feb 27, 2006 | 09:33 AM
KF_Chris's Avatar
Re: Frame Repairing
yeah, I thought about that. I'm hoping that the aluminum didn't get too deformed.
Old Feb 27, 2006 | 10:43 AM
f4stunna's Avatar
f4stunna is a decent person
Re: Frame Repairing
good luck is all i can say cuase it seems like a it has more of a chance not working than helping
Old Feb 27, 2006 | 11:15 AM
Wheeliest's Avatar
Scrapes Elbow
Re: Frame Repairing
f4 frames are cheap n e ways.
Old Feb 27, 2006 | 11:38 AM
crazyzx9rguy's Avatar
crazyzx9rguy is an unknown quantity at this point
Re: Frame Repairing
put pressure on it w/ potapower 1st and then heat up the frame gradually and hopefully you will only need a little bit of heat. Cause you will only need to heat it untill it moves,because the pressure is allready on it. hope that helps, and if you f it up take it to a welding shop and have them weld on a new brkt.
SIC J
Apr 27, 2013 04:53 PM
Twag1992
Feb 20, 2013 05:49 PM
Stefanenyce808
Dec 19, 2012 09:07 PM
wycher
Oct 31, 2012 11:07 PM
DLISH
Nov 25, 2002 05:22 PM
