handbreak problem
Old Feb 20, 2006 | 07:27 PM
shortGSXR1000 is an unknown quantity at this point
handbreak problem
I have a gsxr 600 with stock clipons... i put my hand break on yesterday using a
gsxr front mastercylinder. I ended up having to put the hand break on top because i couldn't get anything to fit with the clutch on top. The mastercyclinder and the clutch adjustment hit each other making ot hard to get the levers even close together. Anyone have any good pics or advice for me on this. I only found a couple pics with the search and none really helped. Thanks
Old Feb 21, 2006 | 08:43 AM
Re: handbreak problem
help please???
Old Feb 21, 2006 | 08:56 AM
OLIVER's Avatar
OLIVER is an unknown quantity at this point
put the clutch on the right side of the hand brake
and run the hand brake below the clutch
Old Feb 21, 2006 | 09:33 AM
OK.. ill try it, thanks
Old Feb 21, 2006 | 09:45 AM
eazenutz33's Avatar
you might have to grond some of the extra junk off the bottom of the clutch perch or lever if you have stock lever and perch......mine had a 1"x1/2" peice of aluminum for the switch on the clutch....bypassed it and ground it off
.....asv lever works better now though
Old Feb 21, 2006 | 10:13 AM
KF_Chris's Avatar
KF_Chris is a decent person
get a clutch cable that doesn't have the bend in it. I'm putting a K5 1000 cable on just to get my HB on the bottom, I'm in the same boat.
Old Feb 21, 2006 | 10:40 AM
Wheeliest's Avatar
Scrapes Elbow
Dirtbike clutch lever/pearch
Old Feb 21, 2006 | 11:24 AM
How did you by pass the switch? My bike will only start if the clutch is pulled in... even in nuetral.
Old Feb 21, 2006 | 11:35 AM
those 2 wires that go into the clutch perch, pull them off and splice them together.
Old Feb 21, 2006 | 01:53 PM
OLIVER's Avatar
+1
msr shorty or msr raptor whatever it is worx great :YEAH
Old Feb 21, 2006 | 02:29 PM
anyone have any pics of the msr or tell me where i can get one
Old Feb 21, 2006 | 02:47 PM
287ridah's Avatar
F*(K Yut Uggh
call your local bike parts store (ex. cycle gear). They usually have them for dirt bikes but they'll fit fine on sportbikes. Just watch out for the thread adjuster. Mine stripped the thread but that could have been my fault. They seem like delicate clutch assemblies, but im sure others have zero problems. Man do they'll make it easy to pull.:YEAH
Old Mar 15, 2006 | 10:32 PM
Cesario's Avatar
Cesario is an unknown quantity at this point
i ended up with an asv, heard that the msr breaks too easy.
bowflexmaverick
Oct 2, 2015 02:16 PM
alex71783
Aug 9, 2015 02:18 PM
Duke_Montes
Jul 23, 2015 11:12 PM
1wheel-wonder
Jul 13, 2013 06:16 AM
