second gear wheelies
Old Feb 15, 2006 | 03:58 AM
kobester's Avatar
kobester is an unknown quantity at this point
just recently started trying to do second gear wheelies after getting first down good. Ive tried the same method as clutching up first but all i get is the springs to unload in the front a bit and thats it. The method im using is get going around 35-40 bring the clutch in a bit rev the let the clutch out ive gotten the revs up around 8-9 grand with nothing happening. The bike is a stock 02 f4i if you can help out please do.
Old Feb 15, 2006 | 05:52 AM
james04r1's Avatar
james04r1 is an unknown quantity at this point
Re: second gear wheelies
you need to be going a little faster. hold clutch in let it hit the rev limiter.then dump it. the f41 is weak and heavy it takes some finess to say the least
Old Feb 15, 2006 | 08:08 AM
-SKETCHY-'s Avatar
STUNTRIDE FRONTLINE
Just Bounce It Up Using The Clutch.just Practice It A Bunch And You Will Get It Down.
Old Feb 15, 2006 | 12:04 PM
SlitZ's Avatar
SlitZ is a decent person
i wouldnt say f4i's are weak...... you could bring up a highchair in second if you weighed over 200lbs no problem... its all about finesse
and DONT hold the clutch in til it hits the limiter then drop it... i hope that guy was jokin when he said that
Old Feb 15, 2006 | 02:27 PM
TotW80's Avatar
TotW80 is an unknown quantity at this point
^^ +1 ya you shouldnt need to rev it up nearly that high, just a lil blip with a good bounce and the front end should be skyward. Its all in the timing of your bounce and clutch release. Are you standing up or sittin down?? i would suggest standin up in stagger position if you feel comfortable with it ... my PEACE
Old Feb 15, 2006 | 05:50 PM
kobester's Avatar
no im trying it sitting down tried a differnet route today tried just bouncing it up with out the clutch didnt anywhere with that. tried bouncing with the clutch need to get better with my timing just got the front springs to unload a bit might of gotten up a little but didnt feel like it. any more good ways
Old Feb 16, 2006 | 10:35 AM
TotW80's Avatar
it really is all in the timing and plenty of PRACTICE PRACTICE PRACTICE! wear your gear and be careful!
Old Feb 16, 2006 | 11:16 AM
KF_Chris's Avatar
KF_Chris is a decent person
give it more gas each time til the front comes up to where you are ok with it and work it like that.
Old Jul 13, 2009 | 05:45 AM
WolfmanJack's Avatar
STILL ON PROBATION!
WolfmanJack is a decent person
+1 that's how I have been learning them, was doing the same thing you are for a while. Increase your revs when the clutch is in a little more each time and it will come up. . .move your *** all the way back as well, once you get it it get easier and easier to do.
Old Jul 16, 2009 | 09:52 AM
zookiezook's Avatar
zookiezook is a decent person
+1
Originally Posted by totw80
it really is all in the timing and plenty of practice practice practice! Wear your gear and be careful!
+1
Old Jul 20, 2009 | 11:11 PM
Ben AKA Rage's Avatar
Clutch it up
Ben AKA Rage is a decent person
just keep working at it it will happen but please dont hold the clutch until it reaches the rev. limit if you still cant get it change out the spockets
cbrdoubler
Mar 13, 2023 04:19 PM
Stunt Medic
May 23, 2013 10:43 AM
Napkin Legend
Mar 9, 2013 12:03 AM
Napkin Legend
Feb 27, 2013 09:56 AM
D-Mann
D-Mann
Dec 8, 2004 08:13 PM
