blade problems
From: www.justmotorcycles.net. moorespeedracing.com. www.theriskclub.com
blade problems
Am i just unlucky or has anyone else that stunts a 900rr or has done in the past broken the engine before?
i have broken mine again so its off to the welder again. lol
Re: blade problems
i had a litte OK BIGISH fall the other day and broke the frame mount and engine then got that welded and had a smaller fall today and snapped the engine casing and a bit of engine were it bolts into
Re: blade problems
I can't believe the amount of damage from that one drop!! wasn't even going that fast!! I was right behind you when it happened
I dropped mine FAR worse today (that SS'er drop) and didnt get nearly as much damage, don't know why your cage didnt hold up??
freestyle on the f4i is proper good.. but on the 900rr? hmmm
Re: blade problems
OI grandad your suposed to be in bed sleeping get off your computer lol
and he's lieing it was like 1 and a hlf feet max lol
Re: blade problems
Well it was a good day's practice.
I got some strange step to ss thing going, Dave broke his bike (again) and sparks got some no handers down.
And my bike's electrics now work, cheers sparks.
Re: blade problems
so are you not going to stansted now dave? and hows your ancle marco you stoppie's are getting good now well done mate.
Re: blade problems
i think its a problem with the blade i broke my engine mount a mounth or so ago it sucks having to drop the motor out, ive also done the big ends on two other engines(forgot to keep the oil topped up) when i can get round to it im going to get a bar welded between the two mounts might help to transfer a bit of the load, but probly wait till i break it again
Re: blade problems
those mounts aren't up to stuntin abuse!!
Re: blade problems
im gonna have to learn to weld and cheers guy's that seems like a good idea.
or a really good idea is iff we all stoped crashing
Re: blade problems
sounds like a brain wave too me
is ther stuff in the way on the f4i i wonder?
Re: blade problems
Good idea that Chris,or even a length of tube with threaded bar would be good? my scrapeworks cage links the two mounts together and is well tuff Re: blade problems
what we need is hardend steel 10mm threaded studing
but u would prolly have to drill out the m10 threads in the engine
but would the cage bend more easy cos the longer material ?
sounds good tho as i ant got any thread left on the right hand side of the engine any way
