Need help with a carb problem
Old Dec 8, 2004 | 08:33 PM
2 Vicious Freestyle's Avatar
Clutchitup.com
2 Vicious Freestyle is an unknown quantity at this point
Arrite, I'll be straight up.
I know **** about quads. My car i can take apart and put back together, But i'm clueless when it comes to quads.
I can get on it and ride it like a muthafkkr, But i dunno about the carbs and ****.
anyway,, WHen i set the warrior, on the 12 bar, it POURS gas outta the hoses that come outta the top of the carb, where the intake tube comes in. and if not there, It'll pour outta teh one that comes outta the bottom.
Now how do i keep it from doin this. Cuz that makes it impossible to do any 12 tricks cuz it just pours gas out.
If i jack the idle all up i can get it to stay runnin, But gas still comes out.
Also when i'm doin super slow wheelies it dies out alot, so i have to constantly be fukin with the clutch to keep it up.
any ideas, I think the carb is phuch'd, But like i said, I ride, I ain't no kinda mechanic.
So please gimme some advice to steer me in the right direction.
I am plannin on gettin a new quad VERY soon, But i still wanna keep the warrior for learnin new **** so i don't destroy the new one. SO i gotta get this worked out
Old Dec 9, 2004 | 08:41 PM
Clutchitup.com
Re: Need help with a carb problem
c'mon anyone, I know some peeps on here have to know about this ****
Old Dec 10, 2004 | 01:35 AM
BRIAN_03's Avatar
BRIAN_03 is an unknown quantity at this point
I cut my idle spring down a little so it can adjust better, and took off the top of my air box to get more air. but you will allways have gas comming out of the overflow tube as far as I know. I ride mine with the idle jacked up all the time so it wont cut out doing slow ****, its hard to do it if the idle is low.
Old Dec 12, 2004 | 12:19 AM
phatdug's Avatar
phatdug is an unknown quantity at this point
Do what brian says there not much you can do it is the type of carb you have on your warrior that is the problem.
Old Dec 12, 2004 | 01:11 AM
Clutchitup.com
thanx, I'll give it a try.
Someone told me sumthin called a float might be stickin in my carb.
ANyone have any input on that
Old Dec 13, 2004 | 06:31 PM
BadAssRR's Avatar
BadAssRR is an unknown quantity at this point
The float height may be off a little, that will cause the die'n out. As for the gas pouring out, its supposed to do that. The quad wasnt designed with "stunting" in mind so at odd angles the carb will leak fuel through those lines so it doesnt flood the motor. I would try pluggin up the lines with a bolt that fits snug and try riding like you normally do and see if it still runs right.
Old Dec 15, 2004 | 08:40 PM
hondahellraiser's Avatar
hondahellraiser is an unknown quantity at this point
my 300 does that all the time. iver tried everything theres nothin to do, maybe float adjustment? but keep tryin
Old Dec 15, 2004 | 10:59 PM
Clutchitup.com
how the hell do u adjust a float, and more importantly what the hell is a float???
I wasn't plain when i said i know nuffin about carbs and ****
Old Dec 15, 2004 | 11:02 PM
jays warrior's Avatar
jays warrior is an unknown quantity at this point
The float is literally a thing that floats in the bottom of the carb. It floats on top of the fuel and turns off the valve that lets fuel flow into the carb from the tank. There should be some type of screw. If not, then you'll have to take the carb apart and adjust it the old fashioned way--with pliers.
Old Dec 15, 2004 | 11:10 PM
r6 n shit's Avatar
r6 n shit is an unknown quantity at this point
sounds like the float is fine to me just jack up the dle and plug the hoses, that is your best bet
Old Dec 15, 2004 | 11:15 PM
Clutchitup.com
see i'm told if i plug all the hoses it can fukk my **** up. Cuz that gas gotta go somewhere.
--*CBR*KING*--
Apr 5, 2022 11:42 AM
Zaradomerix
Jun 17, 2014 09:11 AM
Beastin4shot
May 29, 2014 02:56 PM
hugomferreira
Jun 14, 2013 10:31 AM
dreazoian
Jun 1, 2013 03:18 PM
