Help!!! f4i problem
Old Jul 19, 2009 | 09:28 PM
blee's Avatar
Incredible shrinking man
blee is a decent person
Help!!! f4i problem
YES, I searched for hours n hours before posting,here's the prob.A guys f4i that I practice with stalls out or bogs horribly from the jolt of the bike landing a endo or whoolie,and yesterday it bogged then stalled in the middle of doin O's and he went down and broke a rearset,bike usually runs really strong,and has strong idle,it just started this poop yesterday.When the bike is runnin the FI light is flashin,Has anyone had this happen or know what it could be.We ran fuel injector cleaner with no results and checked for loose FI connections,etc.etc.please help.need more suggestions
Old Jul 19, 2009 | 10:39 PM
shky4's Avatar
Re: Help!!! f4i problem
try seeing what FI code it's giving you
Old Jul 19, 2009 | 10:47 PM
OnEWhEeLNEAL's Avatar
NealFoReal
Did you check the battery connection. If its loose your **** will stall and your FI light will come on. Happened to me
Old Jul 19, 2009 | 11:18 PM
xxMICKEYxx's Avatar
xxMICKEYxx is just really nicexxMICKEYxx is just really nicexxMICKEYxx is just really nicexxMICKEYxx is just really nicexxMICKEYxx is just really nice
delete the codes and then unplug the ECM and see if the problem goes away. .
Old Jul 19, 2009 | 11:22 PM
DIRTYJEFF636s's Avatar
also check the fuel filter
Old Jul 19, 2009 | 11:23 PM
blee's Avatar
Thanks guys, we'll check the battery 2morrow,and how do you delete the code or even know what the code is that it's flashin,it blinked 9 times then it blinked 8 times
Old Jul 19, 2009 | 11:31 PM
xxMICKEYxx's Avatar
8 is throttle pos sensor
9 is the IAT sensor whuch is the one on the front of the airbox
Old Jul 19, 2009 | 11:38 PM
blee's Avatar
damn you got all the code memorized?,I hope we can fix this tomorrow,thanks again
Old Jul 20, 2009 | 08:56 AM
shky4's Avatar
maybe water got in the harness, did the bike get rained on or washed
Old Jul 20, 2009 | 08:59 AM
Ethiopian's Avatar
Soup Mafia
did you crash hard enough that maybe the throttle bodies became loose? check and see if they need to be seated again, its happend to me and it sucks.
Old Jul 20, 2009 | 11:55 AM
NealFoReal
scratch that - i thought it said the FI light came on - not was flashing
Old Jul 20, 2009 | 12:57 PM
blee's Avatar
Headin to the lot to see if we can fix this bitch,thanks for the ideas.I'll post up what we find(if anything) just incase someone else has this happen.
Beastin4shot
May 9, 2013 04:49 PM
kchad917
May 2, 2013 07:20 AM
Demon87
Feb 3, 2013 08:58 PM
xxSHANNONxx
Jan 22, 2013 10:57 PM
Jeffknight27
Dec 3, 2012 10:55 PM
