help help help
Old Nov 7, 2008 | 05:57 AM
burnoutnut's Avatar
SEAT SPREADER COMBOS
help help help
hey guys
i just got some new 05 06 636 forks for my stunt bike.... but because im such a huge **** they bottom out during stoppies (even with everything on hard)
i need to know if i can swap my 03 04 636 fork internals with 05 06 636 internals because my old 636 forks were bombed out with ohlins ...... those boys never bottomed out
Old Nov 7, 2008 | 06:05 AM
Re: help help help
all 05 06 forks i have had did that till i changed the fluid with 10wt fork oil
Old Nov 7, 2008 | 06:08 AM
burnoutnut's Avatar
Re: help help help
is it really that simple?
i must say the braking power of the bigger discs are hugely different
Old Nov 7, 2008 | 06:10 AM
Re: help help help
yes you huge **** you could even use 15wt and have the setting lower but 10 has always worked for me
Old Nov 7, 2008 | 06:13 AM
Re: help help help
and adding a little extra fluid will make the air chamber in the fork smaller , that will have a similar effect as changing to stiffer spring but a lot cheaper ...
oil doesn't compress and air does so more oil less air will act just like a stiffer spring
Old Nov 7, 2008 | 06:14 AM
burnoutnut's Avatar
Re: help help help
will it damage it?
Old Nov 7, 2008 | 06:18 AM
Re: help help help
will it damage it?
no , i mean you don't add a lot ...
put in the recommended amount then measure down from the top of the fork to see where the level is then raise it about 10 mm
burnoutnut's Avatar
Re: help help help
my old forks (even with bombed internals) slmost bottemed out during stoppies
Old Nov 7, 2008 | 06:20 AM
Re: help help help
you fat bastaad ....lol j/k
Old Nov 7, 2008 | 06:21 AM
StrictlyStunt's Avatar
Re: help help help
*****! *shakes fist*
Old Nov 7, 2008 | 06:23 AM
Re: help help help
please use two fingers on the brake ....and the **** ....lol
**** ! what a great ******* word
burnoutnut's Avatar
Re: help help help
trust me i would loved to be shorter
Old Nov 7, 2008 | 06:24 AM
burnoutnut's Avatar
Re: help help help
two fingers is better now omr
ever since you have me the tip
ill get some pics of stoppies tomorrow
Old Nov 7, 2008 | 10:06 AM
Outlawtorn50's Avatar
Outlawtorn50 is an unknown quantity at this point
Re: help help help
Word of the Day:
