Need some Fiddy Help!!! (air/gas mixture)
Old Oct 15, 2004 | 04:48 PM
J-Hook's Avatar
HoOk
J-Hook is an unknown quantity at this point
so i recently added a hi flow air filter to my fiddy and now its not the same on the throttle..... one of my buddies suggested to change the air/gas mixture and now it doesnt seem as strong.... anyone know where it should be set at? (the mixture adjustment screw) anyone know please post up!
Hookster
Old Oct 15, 2004 | 04:51 PM
Z50NATIONALS's Avatar
Re: Need some Fiddy Help!!! (air/gas mixture)
the mixture screw is what you need to adjust
let the bike idle and then play with the screw only turn it a quarter turn at a time the air mixture is only for right off of idle
if your still having problems or its not right on top end try raising the needle a notch if that fails then you need to jet the carb
hope that helps
Old Oct 15, 2004 | 04:55 PM
J-Hook's Avatar
HoOk
so just turn the screw in all the way (or until before it dies,) ride it, if it still feels whack, turn it out a quarter of a turn, rinse and repeat?
Old Oct 15, 2004 | 06:04 PM
hook, another way is to turn the idle up to the point of where it breaks up bad. at that point, move over to the air screw and slowly turn it in or out untill it clears out and runs smooth. then turn the idle back down to where it should be and git r done.
:YEAH
vertical954rr
Aug 31, 2014 04:59 AM
cagivos
Nov 23, 2013 01:49 PM
marcum410
Apr 10, 2013 09:27 PM
rharding91
Dec 21, 2012 04:20 PM
Eric SSB
Jan 7, 2003 06:54 PM
