clutch side engine case leaking oil
Old Oct 11, 2004 | 09:17 PM
jakerosoft's Avatar
jakerosoft is an unknown quantity at this point
ok so i've bent my rear brake lever in so bad, it's caused my engine case to warp and leak oil. I have a new case but was told to be careful changing it. How easy is it to replace? there is a nut in the middle of where the clutch would be, and the kick-starter in the way. Is there anything special i should know before i attempt to swap this out by myself?
Old Oct 11, 2004 | 10:56 PM
adamf4i's Avatar
Re: clutch side engine case leaking oil
dont change it do what i do JB weld it i have done it numerous times you will break it again so there is no use wasted 100 dollars just JB weld or JB quick it everytime trust me
Old Oct 12, 2004 | 09:37 AM
Fuscat's Avatar
If you change it be sure to drain the oil & take off the kick starter and the footpeg mount. Get a new gasket and be careful not to loose the parts that will fall out. There is a bearing plate & cover a spring couple other parts of the clutch. Just make sure you dont loose anything. Its not hard to do at all. I freaked out when I took mine off and parts just fell on the floor but I got the diagram for it and it all goes right back in real easy like.. You will have to readjust your clutch too. (not hard) oh and have some paper towels and **** handy cus there will be alot more oil still in there that will come out when that cover comes off..
Old Oct 12, 2004 | 06:12 PM
imprezawd's Avatar
imprezawd is a decent person
Yo I have JB welded like 4 of mine. If its real bad go to SIK50s.com and go to his Garage sale items. Hes got like 5 Stock OEM Case covers for mad cheap. I just picked up a BLACK case cover with 2 stock oem tires for 20 bucks plus shipping!!! Darryl is the **** down at Sik50s. Hes always just trying to hook it up and earn customers business!!
Hope this helps!
www.sik50s.com
Old Oct 12, 2004 | 11:46 PM
jakerosoft's Avatar
Hope this helps!
www.sik50s.com
thanks, that's where i got the engine case i was talking about above. i'm just gunna jb weld it for now.
Old Oct 13, 2004 | 02:02 AM
imprezawd's Avatar
dont touch that clucth screw and u might not have to adjust anything !
oh yea lay the bike all the way over so no oil will leak out and **** wont drop out everywhere!
Old Oct 14, 2004 | 12:43 AM
DWJmoto's Avatar
DWJmoto will become famous soon enough
I welded mine up made it thicker in that area. it hasn't broke since
Old Oct 14, 2004 | 12:46 AM
adamf4i's Avatar
cool ill try that goob it on there like crazy you get it on there pretty thick
Old Oct 18, 2004 | 12:39 AM
redrider954's Avatar
redrider954 is an unknown quantity at this point
yup mines been jb welded for at least 1 year now no problems
bdhmsg
Feb 17, 2013 07:02 PM
Jope
Dec 10, 2012 06:51 AM
Swavey
Nov 20, 2012 10:36 PM
redlinejesse
Redline Xtreme
Oct 9, 2002 05:48 PM
