Need some ideas for a valve cover breather?
Basically I would have to modify the valve cover I have circled, but what fitting should I use, and where i could get it?
I was leaking a little bit of oil out of the crank case breather so I think I am building up a little to much pressure in there and I think a valve cover breather would help.
ideas/Comments/suggestions?
I was leaking a little bit of oil out of the crank case breather so I think I am building up a little to much pressure in there and I think a valve cover breather would help.ideas/Comments/suggestions?
Re: Need some ideas for a valve cover breather?
Drill a hole in it, tap the hole to accept a small brass barbed fitting, install barbed fitting, use a short piece of hose and a small breather filter. K&N makes some small chrome breather filters that would work for that.
If the cover isn't thick enough material to tap then use a thin nut on the back side. There are a bazillion ways you could make this work.
should have bought a honda...............
they have kits that fit a honda...............
don't you wish you bought a honda........ you could have that fixed by now and not all scared your going to mess up your log of a bike
Originally Posted by dysfunctional
you just mad cause you have spend well over 3k on your "honda" and it still isnt half the bike this is.
yea you still own a bike that a knock off of the honda!
well i hate to break it to everyone, but the valve cover breather i made a while back where I drilled and jbwelded the brass fitting in place.....the jbweld cracked
so don't jbweld it, tap and screw like the other guy said
so don't jbweld it, tap and screw like the other guy said Re: Need some ideas for a valve cover breather?
yea..its true that jbwelds do crack..but mines still doing okay..dont mean to hijack, but heres a thread...http://www.50riders.com/forum/showthread.html?t=425
I've spent less than you and quess what mine is a honda
Actually i did mine with parts right from home depot. Brass threaded fitting, hose, and clamp less than 10 bucks. Drill it, thread it and your ready to go
1wheel-wonder
Aug 28, 2013 07:33 PM
just keep spending money on your bike...
