oil leak?
Old Mar 7, 2004 | 11:00 PM
Yama50_88 is an unknown quantity at this point
oil leak?
ok the other day my 110 went down pretty hard on the left side, bent shifter, gas leak ( the usual ) but then i seen some oil leakin out? but after a min it stopped. and i was thinkin and it did it another time also when i went down on the left side so does anyone know what it could be?
Old Mar 7, 2004 | 11:05 PM
02redr1's Avatar
Re: oil leak?
no ****, i had that same thing happen today, i was doin circles and i guess "lowsided" on the left side, oil was on the ground and i was like wtf?? well, it was coming out the vent, i bet thats what happened, because i bet you don't have that recic box or whatever on either right??
Old Mar 8, 2004 | 01:07 AM
slammedV6's Avatar
slammedV6 is an unknown quantity at this point
Re: oil leak?
did it go down hard on the shifter?? b/c i know that if it bent the shaft that the shifter bolts to it will sometimes mess up that seal that the shifter shaft comes through.
Old Mar 8, 2004 | 08:01 AM
Re: oil leak?
ya it hit the shifter hard but it was comin out the back of the motor like at the top then runnin down the motor then drippin off???
Old Mar 8, 2004 | 09:48 AM
NINER's Avatar
Retired
Re: oil leak?
There is a vent on the top of the fiddy motor towards the rear. Oil could make its way out if you don't have the vent line on it anymore.
Old Mar 8, 2004 | 11:51 AM
Re: oil leak?
i took one of the sides off and there is a hose runnin to the back of the motor i think its a crankcase vent but i'm pretty sure thats where it came from
Old Mar 8, 2004 | 12:16 PM
NINER's Avatar
Retired
Re: oil leak?
I'ts a vent. Dont worry about it.
kmenace
May 11, 2014 10:25 PM
Clint Ewing
Dec 18, 2013 03:51 PM
bdhmsg
Feb 17, 2013 07:02 PM
BANDIT
Apr 14, 2003 03:48 PM
