kitaco big bore problems
Old Feb 8, 2004 | 11:17 PM
de426's Avatar
de426 is an unknown quantity at this point
Angry kitaco big bore problems
I think I already know the answer to my question. I just installed the kitaco 88CC big bore kit with the 20mm carb and cam, oil pump and clutch springs ( Thanks to Don at DPM) I already have an fmf pipe and a kitaco rev box. The bike idles fine and is fine with just a little bit of throtle, wide open it sounds like it is hitting the rev limiter. The plug is black so I know it's rich, just not sure how accurate that is because I can't really run it. I am going tomorrow to get some jets and a pilot jet and think it should cure my problem. Right now it has an 85 main and 35 pilot, I live at sea level. Anyone else have this problem of it running this rich out of the box????? Or is there maybe another problem other than running rich? What jets has anyone used to get this thing spot on? The needle and pilot screw I can mess with once I get the main and pilot right. Thanks, Jeff
Old Feb 8, 2004 | 11:30 PM
Z50NATIONALS's Avatar
Re: kitaco big bore problems
wheres the needle at?
if its in the middle raise it a notch
do that before the jets
Old Feb 8, 2004 | 11:57 PM
Silver Surfer's Avatar
What spark plug are you running the stock? NGK6 is stock ...you need to use a NGK7 or NGK8 with a 88cc Big Bore.
Old Feb 9, 2004 | 12:13 AM
the higher the number on the plug the colder it is
Jimbo7's Avatar
Someone(s) should make a trouble shooting guide for this type of problem, cus I hear about it all too often. Maybe we can start a help group and call it V.O.B.B. (Victims Of the Big Bore).
My name is Jimbo and I have a problem jetting my kit correctly............
Old Feb 9, 2004 | 06:36 AM
de426's Avatar
I already have an 8 in it. I messed with the needle and air screw, it's not doing it in the middle range just WTFO. I am almost 100% sure it's the jetting. I can't think of anything else it could be. Thanks for the input.
Old Feb 9, 2004 | 08:23 AM
https://www.stuntlife.com/forums/174-fiddy-tech-help-how/56552-needle-adjustment-tips.html
all ya have to do is scroll down a few posts and get the best damn info i have ever seen on jetting. i couldnt have put this any better. alot of people get ansy and start turnin screws and changin jets and movin the needle and have no idea how a carburetor even works. do some reading and save yerself alot of headaches. jetting can be very nerve racking. just take yer time and do one thing at a time. that way u know what is working and what is not.
Old Feb 9, 2004 | 09:42 AM
jonnyl's Avatar
jonnyl is a decent person
I am at sea level and i run the 85/35 with the air screw one and a half turns out.Its runs just fine.I would play with the needle a bit.i wouldnt bother with the pilot jet.
Old Feb 9, 2004 | 03:52 PM
de426's Avatar
You are also in a warmer climate. I can smell gas almost like it's flooded. I am going to try the main jets and see what happens. I think with some fine tuning she should runs ***** on.
Old Feb 9, 2004 | 06:02 PM
FIZZ is an unknown quantity at this point
If all else fails, pull the side cover as well as the cam cover and make sure that bitch it timed. I put mine on in my garage and after all was said and done it still didnt run right. Even took it to the shop where i work at and let all 3 techs ride it and they all said it was a carb problem. Well needless to say, before I started messing with the carb, I double checked the timing and sure enough I was off a tooth on the cam sprocket. Fixed that and it ran like a champ. Never messed with the carb, never messed with anything else. I have the Takagawa 88cc big bore kit with the 2 brothers pipe, rev box, super head on it now, the internal rotor, and the STOCK plug and the breather kit for the head and I have NEVER had to adjust the carb. The kit was just the bore kit, pipe, breather and oil pump and carb, all the other stuff I just added and all I did was take the carb that came with the kit out of the box and put it on. Also, on NGK plugs, the higher the number the colder the plug and so fourth, but be careful on how hot of a plug you run, I would just run the stock plug for a while then take it out and read it from there to see if you are running, lean/rich or hot/cold. but don't take my word for it, I only work for a Honda shop.
PS. Hope all that helps.
Old Feb 9, 2004 | 06:23 PM
de426's Avatar
Damn honda shop people, you all think you know everything. Just kidding, thanks for the input. I guess it could be off a tooth, but wouldn't it not be running right at all? I am going to get new jets anyway just so I can tune it for the diff. weather cnditions. I was told that the 85 main is to rich for my area. I will double check to see if I lost the timing. Thanks again.
Old Feb 9, 2004 | 07:42 PM
Actually it will still run fine at idle and with a little throttle, mine was fine even at full throttle if i was just sitting there reving it, but once i put a load on it or started to ride it, thats when it felt like it was losing power and like it was falling on its face and it felt like it was either to rich or to lean or like the carb was clogged, but then when i saw it was off a tooth and i fixed that and rode it before i started messing with the carb and it just wheelies in every gear now.
Old Feb 11, 2004 | 08:08 PM
de426's Avatar
Ok, you were right, the timing was off one tooth. I guess when I put it back together I timed it using the F mark instead of the T mark. OOPS. Bike runs like a rapped ape.
Old Feb 12, 2004 | 09:57 AM
cannabis50Xr's Avatar
cannabis50Xr is an unknown quantity at this point
same problem I had. Off just one tooth lining up that O.. It ran, just real shitty. Now it feels like a unicycle with a motor on it.
Old Feb 12, 2004 | 10:13 AM
de426's Avatar
I think it still needs to a rejet. I ordered the jets already so hopefully it will run even better.
Apr 5, 2017 10:29 AM
phee0220
For Sale & Wanted
Mar 13, 2014 12:04 PM
phee0220
Jan 12, 2014 10:00 PM
phee0220
Dec 23, 2013 01:44 PM
wheelieman2001
Nov 22, 2002 05:53 PM
