72cc big bore kit?
Re: 72cc big bore kit?
Originally Posted by NINER
I figure if I paid $17,000 a year for the last 4 years to learn stuff, I might as well use it.
JUST MY OPINION OF COURSE
Originally Posted by Z50NATIONALS
SOUNDS TO ME YOU WAISTED 68K AND 4 YEARS OF YOUR TIME
Quit being a knucklehead, and by the way it is thermodynamics, not thermal dynamics...no talent *** clown.
your right it is thermodynamics if your talking physics
i didnt see that i typed thermal
but i did my bad
why you callin me names ? showing off ?
do i know you?
im just trying to help out
i posted up pages so you could read it and learn something
without calling anyone names
why dont you post up something that says im wrong
instead of showing your ignorance with name calling
when im wrong im the first to admit it
i like to learn new stuff so post it up ill read it
otherwise shut the **** up and learn something
but i did my bad
do i know you?
:YEAH Re: 72cc big bore kit?
I'm also just giving my opinion of course...
Before you start telling people that their college education was a waste of money and time maybe you should think about it...I went to the same school as Niner..
what school is it? MMI? i went to honda school i went to kawasaki school i went to ducati school factory certified it doesnt have anything to do with racing technology just basics you learn racing stuff by racing and blowing up motors and learning from your mistakes and ill be the first to admit ive blown up a few trying this or that to see what i could or couldnt get away with
anyway.....
temprature websters defines as the degree of hotness or coldness
or othewise a measurment of heat or cold
thesaurus first word after temp is heat
which in a motor is heat from the combustion chamber
your spliting hairs like your horsepower formula a calculation of it not how to make it im not flaming ya
you want heat in the combustion chamber is all i was saying
you want the right amount of it you dont want it all over everywhere else
you say tomato i say tomAto same difference
anyway.....
anyway.....
anyway.....
a 4 stroke motor uses a precise mixture of fuel and oxygen to burn. key word being burn here. we put the fuel into a chamber smash it into a small pancake and then light a match to it for laymen. thus creating Heat and an explosion the force of the explosion causes the piston to move and then the residual motion causes the Heat to exit the engine. if there is no heat there is no fire and if thats happenin your pushin it like a ford. There
it takes heat to move
The otto cycle is an ideal 4 cycle process which contains 2 reversible processes between 2 adiabatic processes. Reversivble-adiabatic-reversible-adiabatic. This is a perfect cycle with no losses.
Oh and by the way, adiabatic means fully insulated.
Oh and you would not feel any heat.
ok let me see if i understand this
the lil gauge in your car the one that has
c----h now is that a thermometer,
a thermalmeter or a temprature meter?
and what is it measuring? measuring temprature?
caused by what? the heat the motor makes?the heat the water makes?
the cold the motor makes? the air in the engine compartment?
sure you spelt that right?
oh i got it
Adiabatic - Without loss or gain of heat to a system. An adiabatic change is a change in volume and pressure of a parcel of gas without an exchange of heat between the parcel and its surroundings. In reference to a steam turbine, the adiabatic efficiency is the ratio of the work done per pound of steam, to the heat energy released and theoretically capable of transformation into mechanical work during the adiabatic expansion of a unit weight
oh i got it
