hand brake
Old Jun 23, 2009 | 11:19 PM
wheeliekid's Avatar
Fate loves the fearless
wheeliekid is a decent person
hand brake
i was hooking up the hand brake to the rear just like some other poeple had posted connected it to the existing bracketry on the rear wheel and using bmx cable. my issue is that:
to keep enough tension on the cable for it to work when you pull the brake,i had to keep it tight enought to where it would actually pull it and lock up when i cut the wheel.
is it because i dont have the black plastic around the wire cut correctly? and the perch and mount some people are showing, does that come from walmart or whatever with the brake cable kit?
Old Jun 24, 2009 | 11:59 PM
jimG's Avatar
Jim G
jimG is a decent person
Re: hand brake
you need to have a perfect length cable,the walmart kit has one in there that works,the cable cant be too long or it wont work,the perch is just the part that mounts to the handlebars,you just use an old broken brake or clutch lever and take off the lever part.put the perch on your swingarm and find a way to fasten the wire part of the cable to the break rod or break arm
if it locks up wen u turn the bars your cables too short or sumthing
Old Jun 25, 2009 | 12:03 AM
jimG's Avatar
Jim G
Re: hand brake
look down like 3 threads under this one and theres a thread homade hanbreak on a ttr, i put a real clear picture of how its done,this should help.good luck man
trdtruck26
May 23, 2013 07:56 PM
greenhornet347
Mar 24, 2013 12:22 AM
f4i knight
Feb 26, 2013 03:06 PM
CRFstuntin
Jan 7, 2013 10:06 AM
OneWheelRegulator
Dec 2, 2012 01:25 AM
