fiddy rear shock
Old Feb 9, 2007 | 04:16 PM
OLEARY's Avatar
OLEARY is an unknown quantity at this point
fiddy rear shock
how the hell do u get the rear shock apart to replace the spring
Old Feb 9, 2007 | 04:21 PM
bloodywanker231's Avatar
bloodywanker231 is an unknown quantity at this point
Re: fiddy rear shock
in the middle of the shock theres a rod, towards the end of the rod theres a little rubber piece....if you slide that up theres a bolt underneth it. Obviously you need to loosen that bolt but you need to heat it up to break the loc-tite(bolt glue) bond. once you get it hot enough and let it cool down you should be able to loosen that bolt and take the whole shock apart.
Old Feb 9, 2007 | 04:22 PM
OLEARY's Avatar
thanks
Old Feb 9, 2007 | 04:24 PM
3824's Avatar
http://sonicjay.com/m50m/downloads/spring-swap.pdf
Old Feb 9, 2007 | 08:19 PM
OLEARY's Avatar
do they have that for the front springs
Old Feb 9, 2007 | 08:25 PM
OLEARY's Avatar
never mind they dont i will be doin tomorrow i ran out of time tonight
Old Mar 6, 2007 | 06:38 AM
F4iON1's Avatar
F4iON1 is an unknown quantity at this point
warning - That nut on the inside of the spring is a bitch. I couldn't break the locktight with a regular wrench. I had to by a set of specialty wrenches made to get off rounded nuts to get it off. Sad part was, this was my 2nd fiddy I had done the same thing to. I had tried everything but seemed like heating it up just made the metal softer and easier to round it off.
b16_rex
May 27, 2025 06:05 AM
joeybaila
Jan 24, 2013 12:20 AM
sbeltinc
Dec 19, 2012 01:22 PM
blayl
Nov 28, 2012 12:47 AM
blayl
Nov 28, 2012 12:29 AM
