rear axel torque spec?
Old Oct 19, 2006 | 08:09 PM
7808's Avatar
7808 is an unknown quantity at this point
i know its just a mini bike but is there a torque spec for the rear axle on a xr50? thanks
Old Oct 19, 2006 | 08:29 PM
322efonic's Avatar
322efonic is an unknown quantity at this point
Re: rear axel torque spec?
get this tight is tight to tight is snap its a 50 come on
Old Oct 19, 2006 | 08:47 PM
7808's Avatar
got it
Old Oct 20, 2006 | 01:25 PM
Crazy D's Avatar
I'M A REGISTERED USER !!
Just make sure you adjust the chain adjusters right and then tighten it pretty good .
Then look to see if adjusters are still set right and feel the chain tension .
Make sure your wheel runs straight . I look at the wheel from the back . It should line up with the top bar of the swingarm (if it is stock)
I adjust my chain when the bike is on the ground and sitting upright . (off the kickstand)
If you do it with the bike off the ground , the amount of slack in the chain will be different when you set the bike on the ground because of the swingarm movement .
Ride and visually check every once and awhile
Old Oct 27, 2006 | 01:08 PM
turboglenn's Avatar
30 Ft pounds is spec from what i remember
richd3000
Dec 12, 2012 10:47 AM
87 ELUDE====>0
Oct 3, 2012 10:18 PM
DBAdrums
Oct 20, 2002 11:40 PM
Jay Carnes
Oct 17, 2002 03:25 PM
