oil pump install..
Re: oil pump install..
If you look on the package of a standard size bit, on most of them under the bit size it says what the metric equivelant is. In other words there is a standard size bit that is the same as 2mm. I can't remember what size it is but just look on the package. one of the standard sizes = 2mm.
i believe the closest thing IS a 5/64, i believe it is less then one thousandth of a difference, but this is just to enlarge the hole that delivers the oil to the cylinder so "dead on exact" isnt needed, but "damn near close" will work, so i will go with your info, thanks!
1wheel-wonder
08-28-2013 07:33 PM
