Fix your brakes for free, Brake modification
Old Jan 7, 2006 | 09:57 PM
GSE_Anthony's Avatar
GSE_Anthony is an unknown quantity at this point
Can't find the original thread anywhere after searching for it, so I am reposting, I thought it used to be a sticky here. I think this is a good thread to have around.
If someone finds the original we can sticky it and get rid of this one.
This was originally posted by Fab5fiddy.
Fiddy F.A.Q. Brake Fix
2000 - 2005 XR/CRF50
By Fab5Fiddy
Fix your brakes for FREE!!
Well, I figured it out. It took me about an hour of staring at my rear brake assembly and drinkin a few, but I got it damnit.
In my opinion, its a design flaw by Honda that has been goin on since the first 50 was made. What we have now would work great if we were trying to stop a bike that was goin in reverse at 35 mph. But that isnt the case is it?
I'll try to explain this as simple as I can. It may be hard to imagine or comprehend at first, but You will understand when all is said and done. Look in the pic at the part labled "brake cam". Look at the direction that it turns and applies force to the brake shoes. The bottom brake shoe is getting pushed toward the drum faster than the top one due to the fact that the cam is pushing on it closer to the area marked "pivot point". It may only be a half inch you say.... well a half inch is enough to screw it all up. This would work sweet if the wheel was spinning the opposite direction because the shoe that is being forced into the drum first is opposing it.
Now what we want to do is change the way that all works and force the top shoe into the drum first (since we are going forward). To achieve this, all you have to do is grind a small amount of material off the bottom shoe (marked in the pic) so it will take longer for it reach the drum. The shoes are interchangable top to bottom so make sure u put the shoe with the most meat on it up top.
Let me know your results. If it still aint great just take a little more material off the bottom shoe. This works. I promise!
Old Jan 8, 2006 | 12:30 AM
Re: Fix your brakes for free, Brake modification
awesome fix
fab5 is god
Old Jan 8, 2006 | 12:33 AM
nickalltogether's Avatar
Yut-ugh.
i'm gonna do it..... eventually
Old Jan 8, 2006 | 05:31 PM
GSE Nick's Avatar
www.GSENick.com
GSE Nick is a decent person
so all i have to do is grind the bottom pad down right?
Old Jan 13, 2006 | 04:44 AM
Miller's Avatar
Miller is an unknown quantity at this point
thats pretty sweet
Old Jan 13, 2006 | 09:52 AM
someone should sticky this
Old Jan 13, 2006 | 10:59 PM
3824's Avatar
not the pad itself - the flat piece of metal on the pad that the cam pivots on ... just make sure the pad with less thickness is on the bottom if it isnt then you will have to sand some of the pad down
Old Jan 17, 2006 | 05:43 PM
louisvillerider's Avatar
sweet...im going to try it...how much ya recommend grinding off?
Old Jan 22, 2006 | 02:56 AM
Jesse W.'s Avatar
Jesse W. is an unknown quantity at this point
My rear brakes are sticking, will this correct that? I noticed that to get them to unstick just stop the bike or roll it backwards.
Old Jan 22, 2006 | 02:57 AM
Jesse W.'s Avatar
Also i put new pads in hoping that would fix it. Do i have to grind the new lower pad?
Old Jan 22, 2006 | 03:16 AM
GundamnitPete's Avatar
Don't read this.
when my buddy helped me out with my brakes, he showed me the dirt and **** all around the cam. he also take some off the top of the pads.
make sure your cam is nice and clean and doesn't have **** all over it.
Old Jan 22, 2006 | 09:28 PM
GSE Nick's Avatar
www.GSENick.com
i shaved the flat spot and a little off the pad...my brakes are fukking ludacris now.......fab is the man
Old Jan 22, 2006 | 10:54 PM
3824's Avatar
did you do the brake mod?
the only reason to grind the pad itself is if it is thicker than the top one - the other option is to just switch the pads around so the thicker is on top
Old Jan 22, 2006 | 10:56 PM
3824's Avatar
make sure averything is very clean also you can ruff up the brake drum with a fine grit sandpaper too that helps ....
also after you clean brakes make sure to put a little bit of lube back on both sides of the cam - i use like packing grease the same stuff i put in the forks(not fork oil)
Old Jan 24, 2006 | 01:55 AM
Jesse W.'s Avatar
Nah i replaced the pads about two weeks ago. Imma try that the grinding and cleaning tomorrow at work. Ill post back to let yall know how it comes out.
Old Feb 13, 2006 | 11:42 AM
shugga's Avatar
Creater/Founder
thats hot! Im gonna try that!
Old Feb 13, 2006 | 11:43 AM
shugga's Avatar
Creater/Founder
stuck
Old Mar 29, 2006 | 09:58 AM
Filipe's Avatar
Filipe is an unknown quantity at this point
Ahhhh im trying to do it now but i dunno... So we grind down where it says "use thinner shoe here" or we grind down where it says "grind this area down"????? Where the brake cam touches or the actual shoe?????
Old Mar 29, 2006 | 10:01 AM
3824's Avatar
where the brake cam touches
Old Mar 30, 2006 | 12:53 PM
alecation's Avatar
alecation is an unknown quantity at this point
OK I tried grinding mine , and I couldn't see much difference on the results... how much do you have to grind?
