need some tuning help
Old Oct 6, 2005 | 08:45 PM
mx_racer32's Avatar
mx_racer32 is an unknown quantity at this point
with the temp changes ive been noticing some changes in my bike.
background info, i have a 3 week old bone stock crf50, only thing that has been done is i changed the oil and switched to an all synthetic lube...
last week the temp dipped down some and i no longer have to choke the bike for it to start, just kick it with the gas on and she comes to life, as well as a slight hesitation right off idle when i twist the gas somewhat fast, if i twist it and hold it, it just bogs and dies...i was thinking i needed some carb adjustment, so i turned idle up a little and the air screw (i believe, right below idle screw) back a turn to see results, then forwards 2 turns (1 full turn from stock in opposite direction), i thought i had it fixed and took it down the road, and it didnt hesitate but it didnt seem to run as strong, it had trouble holding the front tire off the ground, when normally this isnt a prob...so i messed with it some more and before i knew it i lost track of the stock position...whoops.
so anyways i was wondering if anyone could help me out, i dont really know my altitude, i live 10 minutes outside of charlotte, nc if that helps, just looking for some direction, i read the carb tuning sticky at the top but was looking for some more precise\direct info relating to my prob. thanks.
Old Oct 7, 2005 | 11:41 PM
mx_racer32's Avatar
Re: need some tuning help
nevermind, spent some time tonight tuning, got her running about the same as before...
Old Oct 13, 2005 | 08:50 PM
melloyello's Avatar
melloyello is an unknown quantity at this point
Pull your spark plug out and give it a look. You are looking to see if it is all **** black or if there is a white section still showing. Post up what it looks like or take a pic and post it up so I can see it.
Old Oct 16, 2005 | 06:55 PM
mx_racer32's Avatar
checked the plug, black and sooty.(dry, but sooty) funny cause i ride the crap out of it, high rpms, lol i thought it would be clean as a whitsle, im thinking of moving the clip up on on the needle, what do you all think? (a flat tire has me stranded for the moment..)
Old Oct 16, 2005 | 07:40 PM
melloyello's Avatar
If it still has the stock jet in it, I say move the clip up one notch to lean it out some. Or you could do the airbox mod to pull some more air in the engine, might help.
Old Oct 16, 2005 | 11:18 PM
mx_racer32's Avatar
its ALL stock, even the bars, but i can FINALLY do circle wheelies...took my about 3 1/2 weeks (thats how long ive had it) bought it new, i must say though the street tires helps out a ton (in my opinon)
i will move the clip up one and see what happens...gotta get a tube first!
thanks for the help, i'll report back in a few days
Old Oct 24, 2005 | 07:54 PM
mx_racer32's Avatar
moved the clip up, runs a lot better, but its at the very top of the needle now, now more slots..im guessing a bigger needle is in order now? it came stock with the clip just two down from the top.
careless
Dec 19, 2016 10:04 PM
NRA
Mar 3, 2015 01:25 AM
j.torstensson
Oct 15, 2014 10:25 AM
marutin0
Dec 13, 2013 12:18 AM
SlitZ
May 6, 2013 06:24 PM
