Bought my first Fiddy today.. help....
Old Sep 19, 2005 | 08:13 PM
Fallout Carl's Avatar
Fallout Carl is an unknown quantity at this point
Re: Bought my first Fiddy today.. help....
Originally Posted by 006LODBKNY
thanks for all the help.. I ordered the pitking big bar kit for $150.. BBR HD spring for the rear, and Fork Springs for the forks.. I also ordered a set of Motard tires from sik 50's..
question.. are bushings better than springs for the forks?? or is it preference?..
That's a great start. Bars, heavy duty springs and street tires will help a lot.
Bushings are definitely a good idea to do while you are doing the fork springs, they are a big help.
Old Sep 19, 2005 | 08:27 PM
turboglenn's Avatar
^ like C-Dub said the bishings are a great addition while the forks are apart.
might as well do them both at once and save the headache/pain in the a$$ of taking the forks apart twice.
what do the bushings do? : well, if you hit the brake and the tire turns to one side and then returns when you let off the brake...that is the SLOP that is in the factory bushings. throw in some delrin bushings now and you'll never have to worry about that
Old Sep 19, 2005 | 08:54 PM
006LODBKNY's Avatar
006LODBKNY is an unknown quantity at this point
i just ordered the delrin bushings.... what do u think about the BBR HD spring.. with factory shock.??
and the tall seat.. recommended??
thanks. yoooo glen... what's up homie??
Old Sep 19, 2005 | 09:25 PM
Generally the stock shock with heavy duty spring is fine for stunting and street riding, you'll have to see for yourself though, you're a big guy.
Some of the more experienced guys say that some of the more advanced stunts are better with a stock seat. I like the tall seat A LOT, here's why...
I sit almost all the way back on the seat, like most people do. The stock seat, from the back of it, angles down into the middle of the seat, so gravity naturally pushes you forward on it. I found myself pushing my butt back constantly because of that and also having to stand up and shake out the occasional wedgie! The tall seat goes straight across, it doesn't angle down towards the center, so I don't slide forward anymore. Much better.
Old Sep 20, 2005 | 11:41 AM
006LODBKNY's Avatar
yeah.. i was checking out some tall seats last night.. what kind do u rock??
Old Sep 20, 2005 | 03:01 PM
My tall seat is an SDG with a black gripper cover. I think it was almost $90. It was what they happened to have in stock at my local Honda dealer. I like it, I think most of the tall seats are probably about the same though.
Old Sep 22, 2005 | 02:02 AM
50s_rock's Avatar
50s_rock is an unknown quantity at this point
Heres what you need for a pimp *** 50:
BBR super pro frame
Marzocchi shiver 35mm inverted forks
Pro taper mx style bar kit
Kitaco 124se BBK
Two bros. exhaust
Uni Air filter
Billet oil cooler
Super oil pump
Takegawa CDI kit
Daytona 4 speed manual trans
BBR 10" HD rim with HD spokes and rear billet hub With Starcross tire
later....Braaaaaaaaaaaaaap..braaaaaaaaaaaaaa aaaaaaaaaaaaaaaaaaaaaap....braaa..........
cagivos
Nov 23, 2013 01:49 PM
J-EM1BikeLife
Dec 29, 2012 06:38 PM
rharding91
Dec 21, 2012 04:20 PM
Jeffknight27
Dec 3, 2012 10:55 PM
greenhornet347
Oct 15, 2012 02:26 PM
