front springs ? Kunk noise when they unload?
Old Jun 19, 2005 | 12:37 PM
banned101's Avatar
banned101 is a decent person
I installed some longer springs on my sons bike,and they were making a kunk noise when they on rebound or unloading.The guy at the parts place said to fix the problem I needed to go with extended fork legs.Well I installed those only to have the same problem.Im sure I ve installed it the way they are supposed to be ,but I cant figure out why they are still making the kunk noise. Anyone have this problem?
Old Jun 19, 2005 | 01:44 PM
fiddy rida is an unknown quantity at this point
Re: front springs ? Kunk noise when they unload?
do you mean when they max out? because i put longer springs in and the bushings were to small so when i maxed them out the fork tube was coming down and hitting the fork guard mounts. i just threw some bigger rubber bushings in and it was fine.
Old Jun 19, 2005 | 04:06 PM
turboglenn's Avatar
you just need to pack the forks w/ grease reall good, mine "kunk" after i hit too many jumps or drops and push most of the grease back out of them.
just pull them most of the way down, grab a handfull of grease and mush it in the springs and all around teh bushings, then put back together and ride
Old Jun 19, 2005 | 07:16 PM
banned101's Avatar
Was I supposed to use the bushing out of the stock springs? I guess thats my problem then .I asked the guy at the parts place and he said I didnt need them with the extended fork legs and longer springs.
Old Jun 21, 2005 | 09:45 AM
yeah you should defenitly have some sort of bushing in there...doesnt sound like the guy you talked to knows much.
Old Jun 21, 2005 | 03:41 PM
3824's Avatar
yes you need bushings ... if you have upgraded front suspension I would get aftermarket bushings .. like the delrin ...
Tony MPZ
Jan 14, 2016 01:08 AM
Jay Rodriguez
Dec 6, 2012 09:27 PM
njstunt855
Dec 5, 2012 04:34 PM
D-Mann
D-Mann
Dec 8, 2004 08:13 PM
Mickey C.C.
Nov 25, 2002 03:37 PM
