Fork Removal????
Old May 27, 2005 | 09:50 AM
fvc3's Avatar
fvc3 is an unknown quantity at this point
Fork Removal????
How do I get the fork tubes out, so I can put in my delrin bushings?!?!
I took off the tripple clamp & front wheel & brake. I removed the fork seals but it seems like it's just stuck. I pulled down on the fork leg, but it just doesn't come out. Please help. I'm ready to throw this fiddy against a wall
Old May 27, 2005 | 10:21 AM
JohnnyP's Avatar
JohnnyP is a decent person
Re: Fork Removal????
Behind the black rubber bottom fork seals there is a snap ring that holds the legs from slipping out. Remove the snap ring and the bolt at the top and they slide right out.
Old May 27, 2005 | 10:36 AM
fvc3's Avatar
Thank you :YEAH
Old May 27, 2005 | 10:41 AM
JohnnyP's Avatar
No prob if you dont know what to do next you have to remove the spring and aluminum end that holds it to the fork leg. The aluminum end has a pin going through it, punch that out and it'll allow it to slide it off the leg.
joeybaila
Nov 9, 2020 05:52 AM
Brian94tt
Apr 12, 2013 07:40 PM
CMS
Apr 11, 2013 10:01 PM
Ryan Colbert
Feb 28, 2013 01:29 AM
kawasaki622
Dec 4, 2012 10:31 PM
