First gear revving out . . .help
Old Mar 25, 2005 | 09:09 PM
turboglenn's Avatar
Re: First gear revving out . . .help
your probaly feelin like it's doggin out cause you could be revving past teh power range where teh power falls off and fast. as foir the shifting, they don't seem to like to shift well too rapped out, but adjust your clutch according to fab's sticky and you'll be straight on that end.
Old Mar 25, 2005 | 10:26 PM
bikefrk's Avatar
Originally Posted by star skrape
Is there any washers behind the jam nut because my jam nut wont tighten?
Did you take the cover off at all?
Old Mar 26, 2005 | 12:29 AM
turboglenn's Avatar
skrape you get that washer back in and try it?
Old Mar 26, 2005 | 07:34 AM
if the nut wont go back down then the clutch isnt seated all the way in. slide the clutch off while peeking under it. then stick it back on and make sure the small primary gear meshes fully into the clutch hub. then put the locking washer on (the one with the fingers) then a the washer that says "this side out" then the nut.
stuntsquid101
Jul 24, 2016 09:51 PM
musicman3x
Nov 20, 2015 12:01 PM
Jacob Payne
Sep 28, 2015 01:41 PM
FreedomPenguin
Sep 8, 2015 02:06 AM
Duke_Montes
Aug 15, 2015 03:01 AM
