what will happin if????????
Old Dec 10, 2004 | 11:43 PM
=mysterious='s Avatar
=mysterious= is an unknown quantity at this point
I know that this lil box is a exhaust vent for the case......can i remove the box and just run a longer hose???????
or is the box important and do i have to keep it on the bike?
i relocated my key and i want to know what to do with this thing......
Old Dec 10, 2004 | 11:54 PM
Re: what will happin if????????
this black box!
Old Dec 15, 2004 | 09:47 PM
Jimbo7's Avatar
If your worried about it spitting oil outta it, don't worry. The most you'll ever see is just a drop around the end of the rubber tube. If it does spit oil out, you got a pressure build up in the crank case and need to vent it.
Since I race and stunt mine, I put a little water bottle as a catch can and ran the hoses into it. So far the only think collected in it is gas from extensive whoolies
Old Dec 15, 2004 | 09:59 PM
Fuscat's Avatar
you can take it off if you want too.. run a longer hose if you feel the need. If you change out airfilters you can get rid of it all together.. I run the twin air filter and relocated my key. Got rid of it all together. Just ran a longer hose from the case to the back side by the swing arm.. as long as its not plugged you'll be fine..
DrewD
Aug 24, 2009 08:55 PM
gsxr203
Apr 23, 2008 10:18 AM
thatsmerc
Nov 28, 2007 11:51 PM
