Missing power, irradic idling???
Old Nov 15, 2004 | 04:15 AM
stik6shift93's Avatar
stik6shift93 is an unknown quantity at this point
Lately my 50 has been idling pretty iridically, it'll idle fun then just raise up on it's own really high. To the point were you can't really put the bike in gear. I've tried playing with the idle adjustment screw on the carb but it'll just die once the idle goes back down. This happens all the time even when the bike is warm and cold. Also some friends have borrowed it for a while and the thing seems like it's really down on power since i've gotten it back, it barely wants to pull it up in second and not at all in third anymore. I'm assuming it's probably the carb but don't know for sure. Has anybody around had success with rebuilding their carb, or am i just going to need a new one? I also just pulled the plug and it was all fouled out and black. tia for any help
Old Nov 15, 2004 | 04:38 AM
suzuki7davis's Avatar
suzuki7davis is an unknown quantity at this point
Re: Missing power, irradic idling???
Clean the carb, and mess with the air screw a little bit, if the weather is changing it will effect the way it runs as well.
Old Nov 15, 2004 | 10:22 AM
throttle cable could be routed or adjusted wrong. if u turn the bars does the idle go up?
Old Nov 15, 2004 | 03:01 PM
Already tried playing with the idle screw, it's been doing it since the summer so i don't think it's just from the weather change. Also I already checked out the throttle cable and adjuster. Anybody else have any input
Old Nov 15, 2004 | 04:02 PM
FIVEO's Avatar
FIVEO is a decent person
Check your ground and take apart the carb - main jet , pilot jet and clean them along with the float bowl
Old Nov 15, 2004 | 05:06 PM
Z50NATIONALS's Avatar
first off is it a stocker with stock airbox and carb
i love how people give advice without knowing what you have
no one should be able to answer this without that info
if its all stock i would say your mixture screw is off a lil that is what controls the fuel while it idles the black plug means it is to rich check you needle setting to rich will cause the probs you are talking about
the clip should be in the middle of the needle
Old Nov 15, 2004 | 06:47 PM
five0addict's Avatar
five0addict can only hope to improve
z50nati, all carbs will have similar sympoms. also you cant say how the needle should be set. you also know nothing about the bike.
Old Nov 15, 2004 | 07:43 PM
sounds like a vacuum leak to me
Old Nov 15, 2004 | 10:43 PM
cbxr50's Avatar
this cat posts up **** about all kinds of tech questions when he doesn't know a damn thing about a bike obviously. I was going to say along the same lines with five0 and fab. I ran into both of these problems and these two fixes worked for me.
Old Nov 26, 2004 | 11:48 PM
Jimbo7's Avatar
My ct70 was doin the same thing he's taking about. Seemed to be that bolt holes on the intake were stripped causing bad contact with the intake and carb. Re-tapping the holes solved the air leak problem and ran like a raped ape.
Old Nov 28, 2004 | 01:07 AM
what pisses you off more is i at least know more than you
Old Nov 28, 2004 | 01:11 AM
for a stock carb and air box the needle clip is in the middle
no one reads what i say, i said IF
it was a stock set up, do you comprehende the word if
freakin stumps
Old Nov 28, 2004 | 03:42 AM
yup, how mnay factors go into the tuning of the carb? ALOT more than what airfilter you got on!
chill
Old Nov 29, 2004 | 03:31 PM
hey dude how your air filter is oiled will affect how it runs let alone what air filter you have. if not enough oil it will run lean getting to much air if it has to much oil it will run rich not getting enough air
quit trying to start some chit when you know not what you speak of
your a stump
either answer the guys question or shut up im trying to help the guy out
your just trying to start ****
Old Nov 29, 2004 | 03:39 PM
chill
alot more than you can name thats for sure
do you own a hygrometer i bet you dont and i bet youll have to look up what it is
Old Nov 29, 2004 | 03:46 PM
and if its to rich it will idle irradically too
Old Nov 29, 2004 | 04:19 PM
hahahaaa
impressive display, but your still proving yourself as a fool. you want some tuning factors? how about everything off the motor, where the bike is, temperatures, oils, timing...
i dont want this guy to follow your advice and not get anywhere. act like everyone before your advice is wrong because it doesnt matter what components are on the bike, they were giving general advise that will work no matter whats on the bike. LAYOFF YOU FOOL!
hahahhaaaa!!!
Old Nov 29, 2004 | 05:11 PM
yeah ima fool
so you figure out what the meter is and what its for
didnt think so
like i said,you havent said one thing that will help the guy out your just trying to look good by raggin on me which doesnt bother me at all
whats the point gap on a k-o 50? when degreeing a cam where do you put it for advance? how far is to much? what is the optimum temp for a 50 motor at the plug? answer those they are all simple simon questions,well?
read what he typed the plug is black its to rich, which will have less power
dont beleive me turn the choke on while your riding it will instantly fall on its face and blubber
Old Nov 29, 2004 | 05:41 PM
hey Z50NAT, does anyone that you know of make a cam sprocket with adjustability for degreeing the cam? i cant find any for the life of me so i've decided to make a few. sorry to butt in to the arguement. carry on boys.
Old Nov 29, 2004 | 06:36 PM
i love how people give advice without knowing what you have...
the clip should be in the middle of the needle..
read what you said!!!!!
seriously! WTF!
you gave advice without knowing!!!!!!!!!!!!!!!!!!!! your just text to me too, fool!
the plug is black, that doesnt mean anything. do you know if he did a proper plug chop? NO!
simple simon questions? hardly.im not a z50 guy. its not a drag racer its a stock fourstroke hahaaaa
turn on the choke while riding hahahahhaa ok hhaaaahahaaa
im not ragging on you, read what you type!!
relax and stop acting like your not bothered.
