900rr engine case????
Old 02-01-2003, 05:30 PM
BrooklynKid929 is an unknown quantity at this point
Question 900rr engine case????
I am looking at a 1999 900RR but it has a crack in the left side engine case is it expensive or a bitch to fix?
BrooklynKid929 is offline
Old 02-01-2003, 07:28 PM
Crizzymynizzle's Avatar
Crizzymynizzle is an unknown quantity at this point
Put it in the mail I'll fix it depending how bad it is and if I gota split the cases about 150 and up !!
Crizzymynizzle is offline
Old 02-18-2003, 02:41 AM
GEISTSTAR's Avatar
GEISTSTAR is an unknown quantity at this point
4.99$ its called ------ jb weld---its a cold weld and works wonders saved 10 motors radiators trannies u name it its a stunters best friend!!!! and auto store has it--simple 2 use
GEISTSTAR is offline
Old 02-18-2003, 04:56 PM
smb123's Avatar
smb123 is an unknown quantity at this point
You can take it to a trustworthy welder that knows what the hell he's doing (you COULD do MIG on aluminum, but don't settle for anything less than TIG).
And it's important that this person really knows what he's doing because aluminum is NOT easy to weld. I won't get into the technicalities on why, but this sort of job isn't something you do in your garage with your friend's TIG welder.
Obviously it depends on the severity of the crack, though. You might be better off buying an engine on e-bay.
smb123 is offline
Old 02-18-2003, 05:01 PM
uponone's Avatar
uponone is an unknown quantity at this point
I use E-Z Weld Aluminum Welding Rods. They make a really strong repair and can be welded with a propane torch.
You can find em on the net or do what I do and get them cheap on e-bay. http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2509487433
Hope this helps!
uponone is offline
Fred
11-19-2002 07:39 PM
Tick_9se7en3
11-19-2002 05:45 PM
Quick Reply: 900rr engine case????
