Big oil problem
Old Aug 9, 2004 | 03:33 PM
Joe Bar's Avatar
Joe Bar is an unknown quantity at this point
Big oil problem
Hi everybody,
I bought an old blade from '93 a couple of months ago for stunting.People said it was a bad stunt bike because the engine is to weak .The big problem is while wheeling the engine get no oil because this sinks to the bottom.Also I should need an engine from after 95'(less problems with the oil issue)
My questions are a)does an engine from '96 fit on a '93 frame?(which modifications?)
b) which modifications are neccesary for this oilproblem(custom made oil pump or some sort of valvesystem to prevernt the oil from sinking?).
Thanks already.
Joe Bar (Belgium)
ps Hope to see more Americans soon, stunting is growing big time in Europe
Old Aug 9, 2004 | 10:29 PM
wangsta6's Avatar
wangsta6 is a decent person
Re: Big oil problem
i dont know about the engine swap but pull your oil pan off and extend the pick up
Old Aug 10, 2004 | 04:16 PM
Mr. Negative's Avatar
Likes to poop
Mr. Negative is an unknown quantity at this point
Re: Big oil problem
The engine bolts right in. I put a 99' engine in my g/f's 93'. The best way to do it is get a complete engine though carbs and all. Oh and you'll be needing the shifter of a 96-99 also or you'll be shifting backwards.(1 up and 5 down)
iBang
Aug 14, 2013 10:54 AM
Flaherty91
Jun 29, 2013 03:41 PM
Beastin4shot
May 9, 2013 04:49 PM
