need help!!!!!!!! please read asap!!!!
Old Nov 2, 2003 | 01:42 PM
DIGIDY PBR's Avatar
www.purebredriders.com
DIGIDY PBR is an unknown quantity at this point
swaped f4i motor, now all together, but no fuel pump power, hence no run, also the headlight fuse blows immediatly (no gauges or lights) HELP if u can-dlish
Old Nov 2, 2003 | 02:56 PM
DLISH's Avatar
also, when gagues are connected, the lh turn indicator stays on, then off when i unplug the tip over sensor, i also attempted to wire around it w/ no luck
Old Nov 2, 2003 | 05:44 PM
Ridin Disorder's Avatar
Ridin Disorder is an unknown quantity at this point
the f4i has to have the headlight harness plugged in or it will do weird things and it won't turn over. we had one come into my work and the kid had the headlight harness unplugged and it would have power and all the dummy lights were on and it wouldn't turn over, click or anything
Old Nov 2, 2003 | 06:01 PM
DLISH's Avatar
the h/l harness is connected, it ran b4 w/o a headlight, the bike cranks, but fuel pump wont come on (doesnt make noise b4 start up)
Old Nov 2, 2003 | 07:15 PM
prnstar123 is an unknown quantity at this point
hey i posted your question on the r1-forum to see if anyone could suggest something . so far only 1 reply and he said----
The only reason why your headlight fuse would blow is that there would be a short in the wiring somewhere. As for the fuel pump check the fuse for it. If it is ok then run two seperate wires to the fuel pump and check and see if it starts working. If it works then there is a lost connection somewhere.
I will keep checking to see if anyone else replies...
Old Nov 2, 2003 | 09:08 PM
DLISH's Avatar
attn:
f4i and possibly other honda owners, the lh switch and front harness plugs fit eachother
Old Nov 2, 2003 | 10:17 PM
So problem fixed??
Jixr07x
Jun 23, 2013 03:33 AM
ty929
May 12, 2013 09:23 PM
CoryStunt
Apr 25, 2013 05:22 PM
Hizroyalfrshnss
Dec 3, 2012 11:25 AM
