temp brake light conversion for 12-bar
any bike can do this... I wanted to make a temp tail light for my bike so I can ride on roads... so this is what I did... I went to superbrightleds.com they had a matrix of 36 red led in wide spectrium bout 1.5 inches square they poped into 1157 socket... so now I use super small zipps around the square then one that I zipped to paper clips you use to hold a small stack...the heavey duty ones not the normal clips... I had that clip onto a powerful small magnet...then bam stuck to 12-bar and right into socket... real easy fix!:YEAH just thought Id share that
Re: temp brake light conversion for 12-bar
First pic is basicly how it looks..varies sometimes...
This next pic is the magnet and paper clip... thats one small but powerful magnet... also wanna point out that the led's plug directly in stock harness...
why dont you cut a whole for the led's in the tail ? if you try to scrape it those are gonna bust
and how long have you had your 12' bar? it looks minty
first... I am not going for looks... thought thatd be obvisious... and secondly, I wanted something easy to take off on put back on for travel to the store from the spot... this ISNT for perm fix... slap on slap off... basicly when I stunt I got no lights on the front or rear... the less I have on the bike the less will break right?....right... anywho I just got my 12 on the week before this pic and its been crapy weather round here and I work 11hour days 7pm-6am... but wouldnt matter anyway cause I cant scape yet! just starting in on the slow *****... but yeah the stalks are good if you want perm fix which I dont
sighh... true that... also I had a turn signal elimanator kit in with intergrated my turns and tail light which was the best look for anybike... but I wanteds to take my tail off... but yeah winter is gonna ****
speedjunkies
Jan 14, 2013 05:55 PM
