Need help w/ rear brake lever - Billet
Okay, so I just got a Reeg Racing billet rear brake lever (same as Two Bros) in today and I'm having a lot of trouble getting the brakes to work now. I put it on, and for those of you who have put one on know, the hole on the brake lever in which the rod to the drum brakes goes into, is a little farther forward. I pulled the lever (connected to the rod) off of the drum brakes and moved it up so I could get the rod to reach. Now that it does, I can't get the rear brake to work right. When I get it all put together the rear brake drags big time. I tried adjusting the nut on the back to loosen it up, but it doesn't loosen enough, it still drags. I tried re-adjusting the lever about 20 times and still couldn't get it to work. The only way I could get the brakes to work was if the wheel was all the way forward in the swingarm, then I couldn't tighten the chain.
Has anyone else run into this problem? If so, could you help me out and let me know the trick. Thanks.
J.J.
Has anyone else run into this problem? If so, could you help me out and let me know the trick. Thanks.J.J.
greenhornet347
Oct 15, 2012 02:26 PM
