carb/gas problems
Old Jan 4, 2007 | 07:39 PM
pocketracr's Avatar
pocketracr is an unknown quantity at this point
carb/gas problems
my little bro got a mini quad for x-mas and since this is the mini forum, and i kno its not a fiddy but i figure u guys will have the answer, his carb. overflow keeps leaking constantly, unless you turn the petcock off, im thinking it might be a fuel adjust ment screw problem but if any of u have any other resoning let me know, since its new i dont wanna tear into it to just find the problem and mess it up. thanks
Old Jan 4, 2007 | 11:32 PM
xr50s4life's Avatar
xr50s4life is an unknown quantity at this point
Re: carb/gas problems
how bad is it leacking i mean 50's leak all the time its just a fact of motocross...
Old Jan 4, 2007 | 11:36 PM
pocketracr's Avatar
this leak is a tank drainer ok so let me try to explain this as simple as i can, on the carb. the fuel overflow line, the one that runs from the botttom of the carb to under the bike, leaks like crazy, i mean even when your on the gas it still pours out and wastes so much gas. i jut wanted to see if any of u guys had any problems like this because since its new and not mine i dont wanna mess it up or anything. its a cheap 110 chinese 4 wheeler
Old Jan 4, 2007 | 11:48 PM
countomeoout's Avatar
countomeoout is an unknown quantity at this point
you ever have the carb apart?...could be the jet isn't properly seated under the float.
Old Jan 7, 2007 | 12:09 AM
pocketracr's Avatar
yea thats what im thinking now, most likely some dirt up in the bowl of the carburator and stuff. i dont wanna tear into the carb really but it looks like im going to have to. thanks for the help guys
Old Jan 7, 2007 | 12:33 AM
TooTeR is a decent person
my pocket dirt bike has the same problem it leaks gas at a constant rate from the over flow, not just dropping gas, a steady streem! the only thing is that mine dosen't run and i have all ready tore the carb apart and clean everything and but it back together... and it didnt change a thing, ive played with the floats and pin... ive tryed everything and cant find the problem...
Old Jan 7, 2007 | 05:59 AM
Crazy D's Avatar
I'M A REGISTERED USER !!
Where did you get the quad from ?
If it's new , take it back an get a refund or exchange it , or tell them to fix it
Old Jan 7, 2007 | 01:51 PM
pocketracr's Avatar
i got it from a local pocket bike shop, i took it up there yesterday and got their input on it, but they charge 45 and hour to fix it, and if its just as simple as cleanig out the carb then i will do it myself. if its not that then ill take it back up there monday and have them do it
Old Jan 12, 2007 | 11:39 AM
project-c2's Avatar
project-c2 is an unknown quantity at this point
Why should you have to pay, it's new? (Like within 4 months?) Isn't the cost of a new carb 45 dollars?
Old Jan 12, 2007 | 12:30 PM
DoDoddR6's Avatar
DoDoddR6 is an unknown quantity at this point
the floats stuck in the carb... if you dont want to take the carb apart, you can try tapping the bowl of the carb with a screw driver kinda hard... i've been known to pick the front of the four wheelers up and slam them back down to unstick the floats too... ha, no ****... just matters how stuck it is, or how much trash is in it.. just a quick too if you will
Old Jan 13, 2007 | 04:20 PM
eprissel's Avatar
eprissel is an unknown quantity at this point
Same thing here the float is probably stuck, I used to have a 94 Banshee and it happened once in a while, just got to make sure everything is moving freely.
--*CBR*KING*--
Apr 5, 2022 11:42 AM
bowflexmaverick
Oct 2, 2015 02:16 PM
alex71783
Aug 9, 2015 02:18 PM
Duke_Montes
Jul 23, 2015 11:12 PM
