Rear Pegs... problem
Ok.... so i put my rear pegs on, probably not the way i should've though. i welded a bolt to each side, then just slapped a washer and nut on... but they just keep coming unscrewed, and if i wreck it bends the bolt and the nut comes unscrewed, etc etc... so i guess my question is, how does everyone have their pegs set up? any suggestions?
Re: Rear Pegs... problem
you need a lockwasher on there also to keep it from coming undone. what you should do is pm gixxerguy and hell sell you some pegs and a hardened axle. dont put pegs on stock axle, they bend real easy
I drilled a hole in the gusset on the left side of the swingarm and mounted a peg there with Loc-Tite and a lock washer. You don't need a peg on the right. With the bolt setup, if it loosens up, your wheel doesn't fall off.
i think ill get a new axle bolt when i actually get some money
i know what ya mean.. went to bail on a highchair last week and when i came down i smacked my ankle on the rear peg, hurt like ****. had a big *** bruise and some swelling for the last week
Take them off, Pegs hurt really really bad
I used some BMX pegs drilled a hole in one to slip the stock axle through and then drilled and tapped the other. I have crashed it pretty hard and yet to damage the axle.
have you tried taking the wheel off yet? my buddy bent the stock one from just his weight, never even wrecked it
Originally Posted by skinnyR!
Where can I buy a "hardened" axle, stock length.
They got those at like home depot, is there a specific grade or somethin?
on stunt pegs...He has all the different parts - He has probably hooked up half the guys on this site....https://www.stuntlife.com/forums/members/4893-gixxerguy6.html
I used one hole from the chain guard hole and drilled another hole on the other side. I got pegs with threads in them , so usually I can tighten then by hand , and when they bend I hit them back with a hammer, and they been cool for a year, so far I just don't want to mess with the axle
kntmare181
Feb 14, 2013 01:00 AM
greenhornet347
Oct 15, 2012 02:26 PM
hahaa
