Replacing grips
Old Jan 22, 2008 | 03:26 PM
whauburger's Avatar
whauburger is a decent person
Replacing grips
any1 got any smooth techniques to putting new grips on and keepin them from spinning?
Old Jan 22, 2008 | 03:39 PM
kosi28's Avatar
kosi28 is an unknown quantity at this point
Re: Replacing grips
The easiest way to put grips on is used the air gun and blow air into the small hole and it slides right on...or soapy water just make sure it drys prior to riding Now as far as securing the grips you have several choices 1. grip glue (which is messy as hell) 2. use small metal wire.. (loop it around your grip) 3. Ziptie.. (also wrap it around your grip).. im sure there are a buch of other ways but these are the ones i tried...
Old Jan 22, 2008 | 04:02 PM
Compton82's Avatar
Re: Replacing grips
grip glue or electrical tape wrapped around the handle bar
Old Jan 22, 2008 | 04:56 PM
sneed1rr's Avatar
sneed1rr is an unknown quantity at this point
Re: Replacing grips
Hairspray.
Old Jan 22, 2008 | 06:35 PM
Timmy P's Avatar
Timmy P is a decent person
Re: Replacing grips
Spit and safety wire. Honestly now.
Old Jan 22, 2008 | 06:50 PM
whauburger's Avatar
Re: Replacing grips
my friend was telling me 2 saftey wire them but i can't find any wire thin enuf that don't tear my hands up, i don't like wearing gloves alot of times. whered u get the wire from?
Old Jan 22, 2008 | 07:26 PM
Re: Replacing grips
little bit of soapy water and slide them on and let them sit
for a couple Hrs. and Vualla..
Old Jan 24, 2008 | 02:54 PM
Ghini's Avatar
Ghini is a decent person
Re: Replacing grips
aqua net hair spray, when it dries its like glue. if you still have problems with them spinning your holding on too tight and you most likely also suffer from severe arm pump.
Old Jan 24, 2008 | 06:17 PM
Timmy P's Avatar
Re: Replacing grips
No gloves?!? other than your feet what the hell do you think is gonna hit the ground first. Hope you like not riding because you got rash on your hands.. haha. For me. Ill start my bike up and keep riding while your asking people for tweazers and peroxide is.
Old Jan 24, 2008 | 10:55 PM
cisco5311's Avatar
cisco5311 is an unknown quantity at this point
Re: Replacing grips
I always spray a little clear spray paint into the grip, then it slides right on, let it dry overnight and your good to go.
i guess you could use any spray paint, it doesn't have to be clear!
Troy T8
Jul 21, 2015 05:55 PM
Clint Ewing
Dec 29, 2013 10:41 PM
Big Chrome
Mar 13, 2003 02:13 PM
crazeinc
Dec 5, 2002 10:31 PM
