03-04 636 zx6r tip over sensor
does any one have a tipover sensor for 03-04 zx6r 636 i just need the circuit board to be good dont care about the pendulum inside need one asap its my daily driver
Re: 03-04 636 zx6r tip over sensor
there is some way you can connect a certain combination of the three wires together with one loose or grounded or something and you can bypass the sensor all together. maybe roger knows exactly which ones but you could use trial and error to fig it out
Why would you want to remove it? Mine only cuts off when its down. I can hit the cage drifting it and its good.
it mouts up to the frame in front of the battery and has a pendulum swinging with a rod going through and a second half matching up to the black box with circuit board in the picture, you dont have to run the swinging pendulum i just need both black parts to the box and a good circuit board
