95 zx6r parts for sale
Have some parts from a 95 zx6r... need to get rid of them. Make a reasonable offer...
motor, no leaks no nothing... ran when the dude I got it off had it, i couldnt get it to fire. Probably no compression cuz the rings are stuck... no big deal though. Just spray some lubricant in there and im sure it will work.
Green rear rim with a great burnout tire on there
set of forks
set of front calipers
rear caliper
rear rotor
520 chain/sprocket kit... fairly new.. not sure on the sprocket sizes
swingarm... somewhat polished
stock shock
water pump
oil cooler
clip-ons
brake lever/clutch lever
make me an offer. thx
set of forks
rear caliper
rear rotor
stock shock
water pump
oil cooler
clip-ons
Re: 95 zx6r parts for sale
make me an offer on the motor... and the radiator i have is kinda smashed so I dont think you want. It could be repaired im sure.. I will get a pic later tonight for you. the outlet for the overflow.. that little neck is nearly broken off and the inlet to the radiator , below the cap, is squished in but not leaking. have a fan 2.
btw... the motor needs a clutch cover/stator cover. I needed to take those off for my own bike since mine were toast.
Not sure if you still have any of this stuff, but I was wondering if you had an upper as well?
and just out of curiosity...how much for the forks and rim (seperately)?
thanks.
-josh
thanks.
-josh
thanks.
-josh
thanks.
-josh
