Ton of GSXR-1000 parts for sale
03 Front Rotors-Not bent or warped
fairing stay- slightly bent but not broken
Radiator no leaks
Front Brakes complete from master res all the way down to the calipers including braided lines.
03 Forks with triples
Matching lock set ignition, tank, trunk with key
rear sets
shifter with all brackets
rear brakes complete pedal to caliper
stunt plastics tank upper sides tail and seats
carbs
headlamp mint no tabs broke or missing at all!!
Rims front and rear bent a little but hold air and are good for stuntin on
Coolant resvior
swing arm
rear shock mint shape
and some other stuff i cant think of off hand right now, if you want pics just hit me up and i can send em. Or take ones to show ya what ya need to see. Dont waste your time lowballin the stuff i dont need it gone that bad and ebay is a click away.
Radiator no leaks
rear sets
carbs
Coolant resvior
swing arm
Re: Ton of GSXR-1000 parts for sale
How much for your rear brake set up... I need rear set and master cylinder specifically.
Frame? title? need'm... let me know if you got them or know someone who does. Thanks man!
i have a subframe thats straight but missing the tab on the right side of it which i repaired it with an insert ill take 50 for it. For the rearset and master ill do 75 including shipping
what about the whole set of plastic and tank?
also front calipers and braided lines?
Will most of this work on a 02 gsxr6..specifically the plastics, tank, s/frame, swing arm, wheels? How much for all of this if it works?
All of it works on a 02 600 i'll take 200 for the plastics i have front calipers and braided lines pm me for price
post pick of the plastic...I will buy em after I see them...got a headlight...pm me asap
I could use all your fairing bolts, stock undertail, and header springs. How much shipped to 64501?
These are the plastics
i have a headlamp header springs and stock undertail gimmy 150 for the light i have good pics no tabs missing, the springs ill give ya and the undertail ill take 10 bucks for
150 for the lock set, thats for the ignition tank and tail with key of course!
Radiator no leaks
03 Forks with triples (SOLD)
rear sets
stunt plastics tank upper sides tail and seats (SOLD)
carbs
Rims front and rear bent a little but hold air and are good for stuntin on (SOLD)
Coolant resvior
swing arm (SOLD)
rear shock mint shape (SOLD)
Radiator no leaks
rear sets
carbs
Coolant resvior
swing arm (SOLD)
make me a pkg deal 4 locks and headlight, email me at aquickfive0@aol.com
also as of right now i still have the wheels swing arm shock body work no replys back from r6 so its still up for sale if anyone is interested hit me up
Same front rotors as in pic? are they from an 03 1k or other 03 gixxer?
If they will fit k2 1k ... How much shiped to 13090, NY
