Engine noise
Engine noise
I have noticed a noise coming from the engine after i laid the bike down. I don't notice it when the bike is idle and not in gear, once i put the bike in gear and start riding i hear a loud tick/slapping sound that gets louder the higher the rpm's get.
I took it to a dealer and they said that I have bent a rod, but im not so sure that they really checked it out.all they did was take the clutch cover off and look in there.
Now ii was told by someone that has been riding and working on bikes for quite sometime that its hard to bend a rod in those bikes, he said that i prolly spun a bearing.
Any ideas on what it could be?
Re: Engine noise
Its very hard to diagnose something witout actually hearing it.. why dont u post a little clip with good sound of the problem..
only way ive seen a bent rod is if you hydro lock your motor (oil comes into the cyl, piston goes up and stops... bending the rod) if the motor dident stop abruptly i doubt u have a bent rod a crash is not going to bend a rod..
spun bearing is usually caused by lack of oil.. witch wore down the flat bearings in the rod and the surface that crank rides on now has a gap
if its a spun bearing it should make the noise weather its in gear or not.. u rev the engine the tapping gets louder/faster with the revs' if you have no noise with its revved up in neutral it is NOT a spun bearing
if the noise only happns when ur moving you should be looking @ the chain/sprockets. maby missing/bent teeth on a rear sprocket..
deff try and get a little clip up if ya cant figure it out.
Re: Engine noise
the motor never stopped running, it was still running till i took it to the dealership and they tore it apart, and when they gave me a quote of $4500 to fix it I told them no, so they didnt put it back together. So now i have to put the clutch back in,and what ever else is on the right side they took out....lol that should be fun considering ive never worked on a bike other then doing my own oil change.
Re: Engine noise
^^^ what he said but if all that checks out take the chain off n put the bike in gear let the clutch out. go through the gears n make sure it makes easy shifts, n if its still clunkin then its in your tranny. if it is then its likely to be a bent shift fork causing a sliding gear to rub on another gear.
Re: Engine noise
I wish that I could get ya a sound clip but i'm in Afghanistan right now..when i laid it down it put a hole in the stater cover and rev'ed high for a few seconds till i could get back to it...after i got it home I went ahead and did an oil change and filter....
What umm core or w.e they call it are u in over there?
Re: Engine noise
Again u need to check if it makes the noise while the bike is in neutral, that will narrow down what it could be, Bent shift fork would usual make it not shift but a constant click or knock i wouldn't think would be from a shift fork
what core or w.e.? what ya mean?
(Brandon)
May 3, 2014 07:30 PM
