Charging problem please help!
Bike:
1999 Yamaha R1
Problem:
When out riding sometimes my battery dies. I hooked up a digital volt gauge to see whats happening and this is what I found.
At idle the volts sit at 12.0v then randomly will climb to 13.5v. Then the voltage will stay the same when I rev up, even above 5,000 rpms. Then when I let off the throttle the volts drop all the way back down to 12.0v- very strange
What I've tried:
(all tested good but replaced them anyway)
replaced the battery, the Stator, the rectifier
The main ignition (key) switch (had a short thanks to some *** hat wanna be bike theif)
The bike acts the same way after replacing all the above items. help please! why would voltage drop after I let off the throttle and not raise at above 5,000rpms?
1999 Yamaha R1
Problem:
What I've tried:
Re: Charging problem please help!
Check your wiring harness's integrity. Check all the leads right at the stator connection and at the rec plug end for continuity. Sounds like you have a bad wire somehwere. Did the old reg/rec look deformed from heat at all? When they go bad I have seen some short a wire. Also make sure all the pins are tight in the connector, sometimes they can be pushed out and loose contact if they are bent a little bit.
I checked the harness today. everything looks good and all connections are tight. Each part on its own test good. yeah the old rectifier had a slight burn on the RR plug so I replaced that along with the RR and it wasn't deformed or anything
I found the problem. My flywheel bolt came loose again! grrrr! the crank shaft doesn't have aplace for a key to lock the flywheel to the crank so I think thats why it came loose again.
alex71783
Aug 9, 2015 02:18 PM
Duke_Montes
Jul 23, 2015 11:12 PM
