Front brake help
Old Sep 12, 2007 | 06:31 PM
dizzie56's Avatar
dizzie56 is an unknown quantity at this point
Front brake help
I know its probably on here somewhere but since the search dont work, figure ill ask again. I changed the brake lines and i am wondering which part to i bleed first? Do i bleed the master cylinder or brakes themselves? Or does it even matter? Its and 05 cbr1000rr.
Old Sep 13, 2007 | 01:04 AM
MXRACERX43's Avatar
MXRACERX43 is a decent person
Re: Front brake help
fill your master cylinder. Crack the lines at the calipers, let fluid run out for a few minutes, go up to your splitter do the same after you tightened the caliper bolts. Now do the same to the master. Finally compress your calipers with your knees grab the wheel and push in with your knees or whatever. As long as you get the pistons compressed now pump up and do over a few times. It is a lot easier to backbleed air escapes up much easier than trying to force down. With out a vaccum speed bleeder you are almost guranteed to get trapped air in your lines trying to gravity bleed.
Old Sep 13, 2007 | 01:31 PM
dizzie56's Avatar
I got the vacuum bleeder, just wasnt sure on where to start is all
Old Sep 14, 2007 | 01:56 AM
MXRACERX43's Avatar
You got it made then!! Just start right at the bleeders you will suck all the air out with a vac. bleeder.
Old Sep 14, 2007 | 08:51 PM
ecthemc's Avatar
ecthemc is a decent person
b16_rex
May 27, 2025 06:05 AM
stuntin'_cbr
Nov 20, 2024 11:08 PM
blayl
Dec 3, 2012 02:17 PM
blayl
Nov 29, 2012 03:23 PM
unstopablee1
Oct 12, 2012 07:12 PM
