help on how to bleed brakes
Wats up guys, i have a question im very very mechanical ignorant
, im still learning how to work on bikes and do my own tune ups n ****, ok so today i was trying to change the rear brake pads of my sv650s, it was a f*cking pain in the *** (i know what you are thinking some easy ****) so i bleeded the rear brakes by mistake because one of the calipers came off, i finally install the rear pads, what should i do next
, i know i have to add brake fluid, but why every article i read says i need to use a pressure wrench and some other *****, can some1 please brake it down how to bleed the brakes the easiest and simplest way, thank you in advance.
, i know i have to add brake fluid, but why every article i read says i need to use a pressure wrench and some other *****, can some1 please brake it down how to bleed the brakes the easiest and simplest way, thank you in advance. Re: help on how to bleed brakes
pressure wrench LOL do you mean a torque wrench?
You mean you squeezed the brakes with the pads out and your piston came out? LOLOLOLOL
You can do what carm said, or go to autozone and buy a miteyvac vacuum bleeder, $35.. makes bleeding a piece of cake.
told you guys im ignorant when it comes to mechanics lol, what do you mean by crack the bleeder?, so i put the brake fluid pump the brakes 5 times then hold it, continue pumpin till they are hard n ready to go.
There's a bleeder screw on the caliper... put a wrench on it, pump the brake a few times and hold it, open the bleeder and close it again, pump some more, hold, open/close... repeat.
, also which is the right position for the bleeder screw, which way is the number 7 on the screw suppose to go? Re: help on how to bleed brakes
this has gone to far..
same concept,
http://www.popularmechanics.com/auto...o/4213448.html
i love google.
same concept,
i love google.
greenhornet347
Mar 24, 2013 12:22 AM
