Hand Brake & Front Brake off 1 res..........
would it be possible to use the same resivor for the hand brake and the front brake? they r always in the way.
if not, then how small can u go w/ it still being safe?
![shruggs](https://www.stuntlife.com/forums/images/smilies/nixweiss.gif)
Re: Hand Brake & Front Brake off 1 res..........
You need a diaphram to take up the air space as your pads wear down and the fluid level drops.....Also when you get on the brakes the res gets presuraized for a second before the piston passes the res port....Even air in your res makes a difference in pump up, I over fill my res cups before I put the cap on. This makes the system work the best with the least amout of pump up needed.....
My setups only need one pump up, meaning if your on the foot brake the first pull on the HB will be a little soft, but as soon as you go for a second pull its at full pressure....
You really shouldn't need any pumps at all.. Mine and I know Old Man Rogers as well require none
Emgo also makes those small reservoirs
You can see it down there somewhere
going from the foot brake to the HB the first pull has like %95 power, then by the 2nd pull its at %100....Doesnt get any better then that...The difference it so minimal its only noticable to me, anyone else says its the same **** 1st or 2nd pull...
Maybe you dont get what Im saying, even Bill at FT says the same....No matter how good you are at bleeding there will always be a tiny amount of air in the system....
![LOL](https://www.stuntlife.com/forums/images/smilies/LolLolLolLol.gif)
im pretty sure mine's full pressure on the first pull. i gotta check now
![](/images/ranks/live.gif)
![old man roger User spends way too much time asking for rep](https://www.stuntlife.com/forums/images/reputation/reputation_pos.gif)
![old man roger User spends way too much time asking for rep](https://www.stuntlife.com/forums/images/reputation/reputation_highpos.gif)
you have air in your system..............
there is a full line on your resivour for a reason over filling your resivour can cause brake faid because your brakes can drag when the fluid gets hot and expands ,unless you have air in you system.....
Then I tried it on my friends bike with a gptech+hoseclamp. Yes, definitely noticable difference between first and second pump. Not a big difference, but its there. Im gonna try out one of my secret bleeding maneuvers on his tonight to see if I can make a difference.
Im going to try and get some more air out, but the last bleed I did there was nothing but fluid comming out...So I dont know if its gonna get any better then it already is, but who knows bubbles tend to loosen up after I ride the bike...
And every setup Ive put togther is so different I can really compare them, some use FT masters some stock, and all differnt front masters....
