f4i running problem
f4i running problem
i need some help..wen i hit a bump while i'm ridin on the street the bike would try to cut off. wen i clutch it up from dead stop bike would also try to cut off. and then wen it lands the rpms would get real low. i keep my idle up high.. don't kno wat it is exactly. bike trys to cut off from time to time. and it kinda feels like its gona turn off.
Re: f4i running problem
check your terminals on your battery, make sure the bolts are tight. check all the connections twice, did u change somthing or do somthing to your bike before this started happening?
nah.. just ridin.. hit it on the floor pretty hard a couple times. then wen i left the spot **** was startin to act up. like it'll shut off and then cut bak on. it ran fine on the highway. only wen i would hit a hard bump it'll kinda jerk. but at real low speeds it does it.. and wen i try and clutch it up it'll turn off as soon as its comin up.
kntmare181
Feb 14, 2013 01:00 AM
