"Check engine light"
Re: "Check engine light"
if you remove the servo for the exhaust there is a wire you have to unplug out of the harness on the ecu
dont remember maybe its the brown with pink stripe. do a search on gixxer.com im sure some one there can help you.
Ok, Servo wire removed, but my POWER COMMANDER won't work.
(****-if it ain't one thing it's another)
-Guess I'll take the focking bike in to the
"*** RAPE WITH GLUE IN YOUR MOUTH DEALER"
theres also this site called bugmans gixxer, and he knows EVERYTHING so check that out before you head over to the stealership.
http://bugman2.81x.com
bansheewild88
Dec 28, 2012 06:15 AM
I did everything by the book but my check engine light won't turn off.
Any help.
